As yall know I have a 09 zx6r that I had start giving me no spark problems. I'm getting power to the coil sticks checked my wiring and have no broken wires. And I've done replaced the crank sensor. But still getting a crank no start. Any ideas?
Also meant to ask about finding out if there's any codes or not. I've been told I have to have a diagnostic plugged into the 4prong plug under seat and then I've been told to use the mode aDo you have any codes? The ECU must be unhappy -- the two things that that jump out at me that make it unhappy to spark while happy to crank are the vehicle-down sensor and the ignition resistor. Have you done anything to your ignition switch? I'm pretty sure you don't have a camshaft sensor, so the crankshaft sensor should be all you need for the ECU to want to spark.
Yeah you can hear the pump come on when u turn key onYou can bypass the vehicle-down sensor pretty easily -- see this thread: 2019 Starts fine, Dies shortly after | Ninja 400 Riders Forum
Bypassing the ignition resistor is definitely trickier -- do you hear the fuel pump prime for 3 seconds when you turn on the ignition?
(On newer models at least, if the ignition resistor is not present, the fuel pump will not prime when you turn on the ignition. And if the kickstand is down and the bike is in gear, the fuel pump will also not prime -- so be sure those are not the case.)
