Evening Everyone,
Quick question, I have recently been having trouble with air/fuel ratio's, My bike will run very poorly between 3500 - 7000rpm like it's starving for fuel, however if i cover the air ram vents on the front and leave a slight gap it runs perfectly, it has been suggested that this would mean the bike is running leaner then recommended - correct???,
This has only really started to happen since i fitted the K&N replacement filter my question is do i need to richen the mixture after fitting the filter or could there be something more sinster at play ??
Suggestions i have been given so far:-
check the valve clearances - going to use the manual to have a go at it (fingers crossed i don't f**k it lol)
check the condition of the plugs - Brand new checked the gaps before installing
check the mixture screws - trying this in the morning according to the manual should be 2 turns out, right??
Bike is a 95 zx6r
Any other suggestions or help would be greatly appreciated
Chris
Bike is a 95 zx6r
Chris
