Fluid change
5.6K views 4 replies 4 participants last post by  ZoomSplat
#1 ·
A 2004 636...
What is the greenish fluid in the opaque resivoir underneath the engine (center of bike)? Is that coolant? If so how to refilll mine is very low?
#3 ·
the coolant resivor is located underneath the gas tank on the clutch handle side make sure its full you will see a low/full mark & also make sure the radiator is top off with antifreeze also, its located up front underneath the headlights the radiator cap is on the right side of the bike
#4 ·
in the upper right hand corner of your scree, right above where it says "Welcome, Patri0t" you'll see the words "File Vault"
Click on them.
The manual for your bike (03-04 zx6rr) will tell you how to take care of any maintenance you'd like to grease your palms with.
Linky Linky
#5 ·
For some reason the link jumps to page 45 of the manual...but you can figure it out.
