hey my 2nd gear sometimes messes up an goes Neutral, how do i fix this problem or how much will it cost?
I use to thing the same because my 99 250 would have a "false neutral" but it took me actually getting in the engine to find the problem. I will be doing a rebuild within the next year or 2 on the 01 engine and I might do a write up on how to fix it.:OI've done this on my 05 zzr 600. Mainly happened when I first rode I'd shift to second and hit the gas and it would pop into neutral (could feel the shifter move). Think it's from not fully being into second gear.
From what I understand (Please correct me if i'm wrong) the second gear issue for this year is usually caused by missed shifts combined with the weak gearbox. With it converted to GP you shift harder, reducing the risk of missed shifts and saving the tranny. But this is just what i've gathered through trying to figure out how to fix the issue, so it could be wrong. :OHow exactly does GP shifting ease the wear on the transmission, its just the linkage that gets swapped around the forks and everything still move in the same direction its just the linkage and rear set that are changed :O
all this chatter & still not answered :O
I did so mention it.Some say forks are worn, but if your forks are worn your dog teeth are worn. Just start looking for a used transmission including forks and drum on eBay or the forums. Try to find a local tech with a good reputation to do it on the side for you.
I replaced mine myself. $100 fix. You could also get fancy with it and send your gears out to get back cut.
Sorry, missed it dude :O I thnk you posted while I was typingI did so mention it.
^ sorry mate but that's simply not true. The 05/06 gearboxes are known to be weak, 2nd gear in particular.
Yup, known issue with the 05/06, particularly with a track or stunt bike.All I'm saying is when I see a thread on the homepage about gearbox troubles it's normally the 05/06, so unless that year attracts a certain type of rider for some reason, I'd say there's more to it.
