Bike does not start, help identify the issue. - ZX6R Forum
post #1 of 11 Old 03-22-2009, 02:21 PM Thread Starter
Hello, so I posted here once before. I just got my 2003 zx6r this Friday. Its nice and orange has an aftermarket exhaust and a power commander. I am new to bikes so I have very limited knowledge.
Here is my issue: I drove the bike all day yesterday (about 80 miles) parked it in a garage over night. Today as I am turning my key into "on" position my oil light comes on and stays on (the red light with an oil pouring thingy picture), then when I hold the starter button my bike does not start, FI light starts blinking (what does FI mean?) and a clicking noise comes from under the main seat. I though that the noise could be happening from a blown fuse in some part of the bike so I started to explore. After few minutes of wrestling with the wires I found a solenoid that had 2 wires coming in from the right side and one leaving from the left, it also had a 30A fuse in it that was intact (the fuse cover was red, the only fuse with the red cover (I think its the master fuse or something)) Then I tried to turn on my bike again, and that solenoid started vibrating and making the same clicking noise...the bike remained lifeless.
Any ideas what this could be? I am thinking along the lines of a bad solenoid that needs replacement, or a low oil level (since the oil light was one for sometime) but I had no issues with oil level the night before and there were no leaks or anything of that sort.
I am pretty much lost, if anyone have any ideas please share, it would be very helpful.
Thank you.
Ambient is offline
post #2 of 11 Old 03-22-2009, 02:51 PM
mine_us_3's Avatar
I Ride: 2000 Kawasaki ZX6R
Did you try and see if the battery is almost dead? Oh, and Im guessinf FI means Fuel Injection?
mine_us_3 is offline
post #3 of 11 Old 03-22-2009, 03:32 PM
Quarkz's Avatar
I'd have no clue except maybe battery problems, your FI light doesn't usually blink in that instance however. It won't be the oil, the oil light comes on when the ignition is turned on so don't worry about that.
Quarkz is offline
post #4 of 11 Old 03-22-2009, 04:28 PM Thread Starter
I tried turning it on again and now the solenoid makes vibration pulses and FI light goes on in tandem with the vibration. Bad Solenoid?
Ambient is offline
post #5 of 11 Old 03-22-2009, 04:30 PM Thread Starter
BTW battery is good, lights work and the cluster lights up
Ambient is offline
post #6 of 11 Old 03-22-2009, 05:14 PM
ZoomSplat's Avatar
Just because the lights come on doesn't necessarily mean the battery is good. It takes <10 amps to power your whole gauge cluster, and more than 100 to start the bike. You can check your oil level using the site glass on the right side of the engine, near your rear brake lever. Make sure the bike is standing up straight, either on a rear stand or balancing it while you're crouched down next to it.
The fact that the starter relay (not a solenoid, it's a relay) is clicking shows that it works.
Do you have an owners manual? There should be a troubleshooting guide in the back that will list most common reasons the bike will not start.
Is your side stand down and the bike in gear?
Is the side stand switch defective?
Is the battery charged enough to start the bike?
Is the bike equipped with a tip-over sensor?
If so, is that sensor defective, or shorted?
Is your kill switch in the off position?
Blown main fuse?
ZoomSplat is offline
post #7 of 11 Old 03-22-2009, 05:40 PM
sick3sicks's Avatar
it is most def. the battery how do you know yours is good? mine was doing the same thing that clicking noise and i bought a new battery and installed to and bam she started right up i would bet money its that battery good luck keep us posted!
"There are two types of riders thoses who have been down and thoses who are going down"
sick3sicks is offline
post #8 of 11 Old 03-22-2009, 07:57 PM
guy699's Avatar
I Ride: rc51 street 03 636 track 04 husky 450motard 07 crf250 dirt
+1 on the battery. I had the same problem last week on my track bike. I got one on ebay.
guy699 is offline
post #9 of 11 Old 03-22-2009, 08:15 PM
Arlo_007's Avatar
I Ride: 07 ZX-6R & 08 ZX-6R Tracky
+1 on Battery.
Place a Voltmeter across the battery, anything sub approx 12.2 volts and its going to struggle kicking over.
Arlo_007 is offline
post #10 of 11 Old 03-22-2009, 09:11 PM
ZoomSplat's Avatar
Have you tried bump starting it?
post #11 of 11 Old 03-23-2009, 07:45 AM Thread Starter
No I have not, thank you, ill try to get a new battery and see if that will fix my issue. Thank you for all the advice
Ambient is offline
bike does not turn on , clicking noise
98 zx6r run problem u531355 The ZX6R 13 03-06-2012 11:36 AM
bike won't start radu Mechanical and Technical 2 10-23-2011 04:34 PM
Bike wont start! help 1sikride The ZX6R 7 08-26-2009 10:06 PM
