All balls Fork Seal Fit? - ZX6R Forum
  • 1 Post By NatBrown
  • 1 Post By the prophet
post #1 of 14 Old 02-12-2015, 06:08 PM Thread Starter
TheSloMoShow's Avatar
I Ride: 04 ZX6R & 04 R1
Hey guys,
In the midst of rebuilding my forks and I just got a new oil and dust seal kit from All Balls racing. The oil seal fits perfectly, but the dust seal.....well it doesn't look anything like the OEM dust seal? I'm scratching my head wondering wth to do with it, is this truly how they've constructed their dust seal or should I be looking to buy a pair of OEM?
I have the OEM dust seal resting against the All Balls dust seal on the lower fork in the picture btw.
If you aren't first, you're last
TheSloMoShow is offline
post #2 of 14 Old 02-12-2015, 06:19 PM
As long as the diameter for the tube and fork leg are correct, I wouldnt worry about it. The one not in the fork has an internal spring, the ones in the fork have external. Two ways to accomplish the same thing.
PainfullySlo is offline
post #3 of 14 Old 02-12-2015, 06:32 PM Thread Starter
Thanks for the reply. Lol, I bought another kit online thinking the one I first bought wasn't meant for the 03/04 Zx6R. Now I have an extra one....
post #4 of 14 Old 02-12-2015, 08:10 PM
40acres's Avatar
I Ride: 2008 zx6r, 2011 kx250f
it actually looks like those are the wrong seals (too big). They're sitting where the wiper installs.
40acres is offline
post #5 of 14 Old 02-12-2015, 09:09 PM
NatBrown's Avatar
Just buy the OEM seals. They are superior to most of the aftermarket ones.
lucasstunts likes this.
NatBrown is offline
post #6 of 14 Old 02-13-2015, 05:31 AM Thread Starter
Hmmmm....I was supposed to work on re-installing these this weekend. Darnit, may have to wait until some OEM seals can come in
post #7 of 14 Old 02-13-2015, 09:59 AM
Have you measured the diameters of the seals?
I would normally go with Nat in that there are some things that I strictly use OEM but bearings and seals I get from AllBalls for every bike and never had a problem. They make some quality kit.
post #8 of 14 Old 02-13-2015, 04:22 PM
TheEvilTwin's Avatar
I Ride: ZX6, ZX10, BMW
IMHO and experience, you will see a much more trouble free service life out of OEM seals and sweepers. Not that you shouldn't use aftermarket, just that OEM last longer.
CCS 132 Proudly sponsored by Amsoil, DC-MOTO.net, Manassas Honda Kawasaki and MARRC
2014 #1 RCGT, #2 MWSB, 2014 Sportsman Award, 2013 Amateur of the Year, 2012 Cornerworker of the Year
Follow Motosylum Racing
R6- Bonnie the Pirate 6
R100rs- 66k and counting!
R1200 GS/A- The moose is loose!
KTM 400 XCW- Riding dirty!
TheEvilTwin is offline
post #9 of 14 Old 02-13-2015, 08:49 PM Thread Starter
The ID of the seal that actually comes in contact with the silver housing is 1mm shorter on the aftermarket kit than the OEM seal.
While I've never seen a wiper like this on any sport bikes I've owned, my brother mentioned these are common on dirt bikes.
I think I'm going to run with it, I really don't see any reason to buy OEM ones at this point when these should work just the same. I'll be the guinea pig for the forum
post #10 of 14 Old 02-13-2015, 08:58 PM
I Ride: franken636, f4i
i've run all balls bearings with no problems but, i know plenty of stunt riders and motocross riders that dont think much of all balls fork seals. oem seems to be the consensus.
lucasstunts is offline
post #11 of 14 Old 02-13-2015, 11:01 PM
ZXROM's Avatar
Got that seal kit for my bike, seems like a good quality material and product, comparable to oem, I can report back after a few thousand miles.
ZXROM is offline
post #12 of 14 Old 02-14-2015, 04:47 PM Thread Starter
Exact same kit, the wipers looked the same as the ones in my picture?
post #13 of 14 Old 08-26-2016, 07:02 PM
Anyone else? I'm replacing mine soon. OEM or aftermarket? I would think all balls seals would be of similar quality as NOK. Either way seals are not expensive but just looking for reviews.
post #14 of 14 Old 08-26-2016, 08:32 PM
Use the All Balls. Be sure to check the tubes for nicks. Most often a nick will damage the seal and make the fork leak. If you find a nick sand it out with 600 grit , 800 and then 1,000.
jd41 likes this.
the prophet is offline
fork seal bakestar The ZX6R 24 03-09-2013 07:20 PM
2003 zx6r fork seal zixxersixxer The ZX6R 1 03-04-2013 11:08 AM
Fork seal leaking? osborn88 Mechanical and Technical 15 09-28-2012 12:52 AM
2003 zx6r fork seal leak =( clange2409 Mechanical and Technical 4 08-29-2012 02:39 PM
A question to all that has done a fork seal replacement on a 03-04 zx6r budro The ZX6R 1 06-01-2009 03:05 PM
