Backfire with Graves Exhaust - ZX6R Forum
  • 1 Post By Aubrey
post #1 of 14 Old 10-21-2014, 01:40 PM Thread Starter
Just put on my graves and noticed there is a lot of "after fire"/"back fire" when riding. Mostly on low rpms and when downshifting. I read a few threads about this and there seems to be no consent or a straight answer if I should worry about this?
Blockers? Retune stock computer? Get a new pc? Leave it?
danielson is offline
post #2 of 14 Old 10-21-2014, 01:58 PM
Burnt toast's Avatar
I Ride: eye candy
Block off playes. Pcm. Tune. Done
At least it's not a 2007-2008
Burnt toast is offline
post #3 of 14 Old 10-21-2014, 02:08 PM
cdn ws6's Avatar
I Ride: 2013 ZX6R ABS
I have a Graves slip-on on my bike and for what it's worth, when letting off the throttle it does "crackle" a bit but not really back firing. It's a pretty free flowing system but I honestly wouldn't worry too much about it.
2013 ZX6R 636 ABS, Shorty levers, Puig windscreen, Racefit Growler slip-on, Michelin Pilot Power 3's, Targa fender eliminator, Integrated tail, Yoshi frame sliders and spools, 5000k 35w HID's, Black solo cowl, Evotech blanking plate, Techspec Snakeskin tank grips, BMC Air filter
cdn ws6 is offline
post #4 of 14 Old 10-21-2014, 02:11 PM
If it's just a slip on then do the block off plates and it should kill the popping/afterfire on decal. And might as well remove ALL the smog shit at that point too.
If it's a full system and you haven't added a fuel management system to the mix then make that happen.
PowerGroove is offline
post #5 of 14 Old 10-21-2014, 02:34 PM
zx racer's Avatar
I Ride: 04 ZX636
No need for pc,tune if your runnin slipon... Get some blockoff plates that get rid of noise you hear.
zx racer is offline
post #6 of 14 Old 10-21-2014, 03:00 PM
jerryg951's Avatar
I Ride: 09 zx6r
Yeah block off plates will.fix that quick.
jerryg951 is offline
post #7 of 14 Old 10-21-2014, 03:08 PM
ilotek's Avatar
I Ride: 2013 636
block off plates and a tune will remove most of the backfiring. i also have a graves slip on + gutted headers.
"withhold no sacrifice, grudge no toil, seek no sordid gain, fear no foe. All will be well."
ilotek is offline
post #8 of 14 Old 10-22-2014, 08:05 AM
Aubrey's Avatar
I Ride: 2009 Yamaha R6
What they said, Graves and Driven make nice block off plates too.
PowerGroove likes this.
Aubs
Aubrey is offline
post #9 of 14 Old 10-22-2014, 10:10 AM
Texas636's Avatar
Sounds like everyone said pretty much what I was gonna say.
Keep it alive with the Graves and get their block-off plates. If the problem still persist, get a PCV or a Bazzaz and richin it up.
Texas636 is offline
post #10 of 14 Old 10-22-2014, 10:21 AM
badgerninja's Avatar
I Ride: 1986 Nishiki, 2015 Yamaha R3
Consensus?
Bleeding heart liberal
You do what you can for as long as you can, and when you finally can't, you do the next best thing. You back up but you don't give up.- Chuck Yeager
Originally Posted by Fishbowl
Go ride Badger for it's the only thing that'll make sense at times.
badgerninja is offline
post #11 of 14 Old 10-22-2014, 11:18 AM
weaponzero's Avatar
I Ride: 2000 Suzuki SV650 (Sold), 2006 Kawasaki ZX-6R SE (Sold), 2014 Yamaha FZ-09
This is one of the main differences between slip-on vs. full system. Installing a full system necessitates also installing block off plates and either getting a dyno tune or ecu flash or installing a fuel controller. Without all of this your air/fuel mixture will be way off and your bike won't run right.
Basically you just opened up a money pit for yourself by installing that full system =P
weaponzero is offline
post #12 of 14 Old 10-22-2014, 01:30 PM Thread Starter
Originally Posted by badgerninja View Post
Consensus?
Yea, thanks
Slip on
post #13 of 14 Old 10-22-2014, 01:59 PM
Manolo's Avatar
I love the sound it makes when it backfires, kind of miss it. But I do hear it once in a while and brings a smile...
| Akrapovic Ti Evo | BMC Race Air Filter | Brembo RCS19 Master Cylinder | ECUnleahsed | Galfer Wave Rotors | Goodridge Superbike Pro Racing Brake Line Kit | Healtech Speedohealer | Jumper Mod | Kleen Air Mod | Motion Pro Revolver Throttle Kit | Ohlins 30mm Cartridge Kit & TTX Shock | Power Commander 5 | Ram Air Mod | Renthal Clip Ons & Kevlar Grips | Scotts Damper | Vortex -1/+3 Sprockets & Rearsets | Woodcraft Frame Slider |
Tuned 120.12 HP 46.58 FT LB Torque
Manolo is offline
post #14 of 14 Old 10-22-2014, 03:51 PM
Muilisx
Guest
Posts: n/a
Backfiring is normal without a PCV or some form of tuner but backfiring sounds cool. It's nothing bad really. It's just fuel igniting inside the exhaust on its way out.
Hotbodies Exhaust 03-06 lil636 Mechanical and Technical 6 05-23-2011 05:20 PM
question about aftermarket exhaust and taillight and plate mounts,servo etc MJW7800 The ZX6R 0 05-09-2011 06:45 AM
Micron ultralite exhaust OR Level One Racing exhaust? that636guy The ZX6R 1 05-15-2009 07:14 AM
