Grinding noise - Page 2 - ZX6R Forum
 5Likes
post #16 of 58 Old 11-18-2013, 11:22 AM
Zx6rlover06's Avatar
I Ride: 2006 zx6r
Does it sound like metal rubbing metal, or actuall grinding? Because if something is making a grinding noise on my bike it's being parked untill i figure out what the hell it is.
*Shit happens*
Zx6rlover06 is offline
post #17 of 58 Old 11-18-2013, 11:23 AM
I Ride: 2006 zx6r
Also when i think of grinding i imagine the sound of a girl grinding the gears in a truck, is that the type of sound your hearing lol?
*Shit happens*
post #18 of 58 Old 11-18-2013, 11:40 AM
NEPAzx6r's Avatar
I Ride: 2005 ZX6R
Originally Posted by badgerninja View Post
I'm pretty sure I hear the noise only when the bike is running. And the noise is to my left, instead of the right where I crashed, leading me to suspect something with the chain.
I went down in a slushy gravel-mud mixture, doing probably around 25 mph. I don't think it was an exceptionally hard crash, but you never know. How hard of a job is it to inspect?
I've never taken apart a clutch but I'm pretty sure you can inspect it and notice anything wrong just by disconnecting the cable and pulling off the cover. Maybe take a picture and throw it up and see what everybody thinks? Don't forget about the oil though.
Also, maybe check the chain alignment. Coulda knocked something out of wack when you went down.
Originally Posted by zninja View Post
All I wanted to do was get away and Mariah Carey made me beat up a child.
Originally Posted by Street Hawk View Post
I think my girlfriend is a squid because she rides me real hard with no gear on.
Originally Posted by beckzach05 View Post
Spark plugs don't lie, they don't hide shit from you, they lay it all out there like a geisha girl with sushi on her bits.
NEPAzx6r is offline
post #19 of 58 Old 11-19-2013, 07:04 AM Thread Starter
badgerninja's Avatar
I Ride: 1986 Nishiki, 2015 Yamaha R3
Thanks guys... now I'll need to do some digging into and reading before I bring my untrained hands anywhere near the clutch. It is under factory warranty though, so should I take it to a dealer? Will they complain that since it was dropped, it won't be covered?
badgerninja is offline
post #20 of 58 Old 11-19-2013, 09:01 AM
Originally Posted by Zx6rlover06 View Post
He said in the 6k rpm range so it shouldnt make a difference unless he holds the clutch in while ridding at 6k lol then it would be obvious it's a clutch issue. Im thinking maybe a loose bolt like on the front of gas tank or your missing one of those little rubber pads that stop vibration in spots like where the gas tank meets the frame. It did it on my old 1997 gsxr750 while idling only, just post a video of the noise.
It would make a difference because if the bike is sitting in neutral and he revs it up to 6k and he doesn't hear the noise, that would mean it's not engine related and would be clutch/chain/sprocket related. But if he hears the sound at 6k rpm in neutral sitting still in the driveway, then it means it is 100% not sprocket/chain related as none of those components would be moving.
Redgeneral is offline
post #21 of 58 Old 11-19-2013, 09:45 AM
I Ride: 2006 zx6r
Ok but it wouldn't mean that the clutch is bad if he is not using it and it's only in the 6k rpm range and not any other range
*Shit happens*
post #22 of 58 Old 11-19-2013, 07:59 PM Thread Starter
Attaching some pictures of what the front sprocket looks like and the side of the crash. If nothing, these hopefully will help eliminate potential sources of the noise.
It was a mostly noise-free return back home following the photoshoot, and I didn't hear anything around that rpm range till I was almost home and then it came back with vengeance.
Hope this will help you chaps somewhat in the diagnosis... any insight is highly appreciated, thanks!
post #23 of 58 Old 11-19-2013, 08:31 PM
ZXROM's Avatar
Ok, 6000 rpm, any gear? What about standing still in neutral at 6000 do you hear it? what about sitting still in 1st with clutch lever pulled in at 6000 do you hear it? Report back, nothing obvious with the pictures.
Is it me, or is your chain hanging like a sleeve of a wizard?
Why do you have oil all over the frame, swing arm and back wheel?
ZXROM is offline
post #24 of 58 Old 11-19-2013, 08:42 PM Thread Starter
Yeah, pretty much any gear, though I've definitely experienced this between gears 2 through 5. In neutral, I hear nothing around that rev range. Even when riding, the noise isn't there all the time, but is present over half of the time. I haven't tried the sitting still in 1st with clutch engaged... will report back tomorrow on that.
I checked the chain slack the other day... was around 1.5", kind of in the higher limit.
That is merely chain lube that got sprayed onto everything... need to wipe that up.
post #25 of 58 Old 11-21-2013, 09:28 AM
oKayH's Avatar
Crashed on the right but grinding sound from the left, are you 100% about that? Is said grinding sound at a slow or fast rate? After you crashed, did you loosen bolts of the axles, engine, forks, etc to let everything "reset" itself from potential tweaking? I'd prob do that first, with the rear wheel esp, and make sure it is aligned properly (via chain, not the swingarm notches) and do an overall once over of everything else without bodywork on.
BTW, I have no f'ing clue either, just throwing things out that make any kind of sense. If you can't get video while riding it, a local reputable shop might be worthwhile
CCS EX
More gas, less brake
oKayH is offline
post #26 of 58 Old 11-21-2013, 09:36 AM Thread Starter
The sound is definitely from low down in the left side, which was what got me to suspect the chain and sprockets. As far as rate, it is a high-pitched shrill, as it you were cutting metal or even welding, thought probably not as loud. It isn't there all the time, but when it does show up, you can sustain it by holding the throttle around 6,000 revs.
I haven't opened up anything else on the bike... don't have all the tools. But it does sound like a good idea, and I'll begin looking into it. The chain alignment is a good idea, and I can do an earlier oil change as well... which is when I can inside the bodywork. Otherwise, it is the shop for me.
Thanks for the immediate advice, chappie... really appreciate all the help!
post #27 of 58 Old 11-21-2013, 12:57 PM
Could it be the radiator fan making the noise when it kicks on? It could have gotten misaligned int the crash and may be rubbing on something now.
post #28 of 58 Old 11-21-2013, 04:26 PM
oldninjadude's Avatar
I Ride: 2007 ZZR/ZX6R
Aside from what has already been said?
Have you put it on stands & spun the wheels, Bounced the suspension?
Looked closely at the brakes?
I'd first check all parts that move.
Have a close look at the linkage, lay on your back & slide under the bike.
& that front sprocket & cover, Cleaner than mine. I think your gtg there.
read only one page"
oldninjadude is offline
post #29 of 58 Old 11-21-2013, 04:29 PM
On more thing, If you take it to the dealer, Theirs no rule says you have to tell em it started after the crash.
"I was on my way to the shop to report this sound when I crashed"
Crashz28 likes this.
read only one page"
post #30 of 58 Old 11-21-2013, 05:17 PM Thread Starter
Thank you so much for the reply, OND. I haven't looked at the suspension or the brakes, so will definitely give that a try. I'll be getting my hands on a rear stand soon. Would you advise parking it till I do all of this? The sad thing is I've probably put on 500-plus miles since I noticed the sound... gasp!
Whinning noise when bike is off usmc zx6r Mechanical and Technical 12 10-22-2013 09:14 PM
HEEEELPPPP(Rattle Noise) Dremers The ZX6R 5 05-01-2013 08:27 AM
Weird noise coming from the rear end of the bike kidraven Mechanical and Technical 6 04-13-2013 01:33 PM
Stator replaced. Strange whirring noise? ZXDrew Mechanical and Technical 2 12-07-2012 07:49 PM
Grinding noise? Dart Mechanical and Technical 7 03-16-2012 05:09 PM
