urgent! changing spark plugs now - ZX6R Forum
post #1 of 7 Old 04-30-2008, 04:36 PM Thread Starter
does anyone have any pointers for changing the spark plugs? we cant seem to get to them and we don't know the size of socket we need, i would greatly appreciate a fast response thanks, its for a 98 zx6r.!! thanks!
cyraxx is offline
post #2 of 7 Old 04-30-2008, 08:27 PM
find the sparkplug your changing them out with.
and put them in a socket to find the right size.
and on mine, i had to tke the radiator off.
along with the tank.
they can be a pain.
hope that helps
Scabbs is offline
post #3 of 7 Old 05-01-2008, 03:18 AM
18mm
Ribit is offline
post #4 of 7 Old 05-01-2008, 04:16 AM
get a sparkplug socket that has a piece of foam in it so they don't drop out and it's 5/8" socket
no real pointers to give other than to put the socket on the extenstion, then put that down the hole and then attach the ratchet after the socket/extension is connected to the plug, it'll take about 20 minutes
selfinfliction is offline
post #5 of 7 Old 05-01-2008, 06:04 AM
I find that on my ZX6R it works the best with the tank off. After that I use a short extension on the socket with a universal joint then a longer extension. That setup will allow you to get enough bite to loosen the plugs and not have to rip the bike apart. Good luck
steveo1312 is offline
post #6 of 7 Old 05-01-2008, 09:03 AM
I take the tank off to make it a bit easier
but it's still a cunt!!!
champagne1973 is offline
post #7 of 7 Old 05-02-2008, 07:42 AM
i took off the tank and the airbox and it was mad easy...your bike comes with a tool set from kawi and i used their spark plug socket...fit right in
BBlue is offline
spark plugs question Cap Walker The ZX6R 22 02-24-2013 03:28 PM
Help changing Spark Plugs mounty50 Mechanical and Technical 3 09-20-2011 01:46 PM
E3 spark plugs sportryder Mechanical and Technical 15 07-07-2011 08:10 AM
spark plugs..07 zixxer Robbo1 The ZX6R 8 03-27-2011 12:45 AM
Spark plugs nlutfi Mechanical and Technical 8 03-15-2011 06:37 PM
