636 Won't start...What haven't I tried??? - Page 2 - ZX6R Forum
post #16 of 19 Old 08-27-2012, 09:26 AM
Hitman123's Avatar
It was originally the battery I'll put money in it. It happened to me. I think when u where messing will the idle screw u probably left it too low that's why it would cut off. Just like the guy above me said keep and eye on the battery just to make sure.
Hitman123 is offline
post #17 of 19 Old 08-27-2012, 10:32 AM
Originally Posted by powerhouse21 View Post
Ok I have a 2006 zx636 about 20k miles. It has run perfectly fine up until about 2 weeks ago. I started it up and noticed it was idling kinda low but nothing really to concern myself with...or so i thought. I go to pull out of my complex and notice that it is sluggish when I try to give it throttle so I turn around and bring it back home. I cut it off and try to start it again and it barely starts and then cuts off and dies. Now it won't start at all. Here is what i've done to try and fix it. Battery is about 5 months old so it SHOULDN'T be the battery, but i will charge it tomorrow and see what happens. Changed spark plugs, changed fuel pump/filter, drained gas tank and refilled with gas, changed top fuel rail assembly/fuel injectors (the ones on the top part of the airbox). Now when I start it, it makes this buzzing/fast clicking noise. Idk if it's the starter or rectifier?
check for water in your gas tank...it says you tried that already...hmmm not sure then
06sixdirty6 is offline
post #18 of 19 Old 09-02-2012, 12:48 PM
spiderman636's Avatar
I Ride: 2005 zx6r
I am having this same problem right now.. I have a battery charger and I charge the battery but it still wont start it comes a heck of a lot closer but still doesnt start and if I plug the charger back in it would take 10 or 20 minutes to recharge it again so its not holding a charge at all... should I replace my battery? or is there something else I should try before dropping the money.
spiderman636 is offline
post #19 of 19 Old 09-02-2012, 04:37 PM
AgentOrange's Avatar
I Ride: 1995 ZX6R F1 Cafe'd, 1972 Suzuki T350, 1992 KDX200, 1966 YDS-3, 1999 KE100 w/KDX400 motor
if its not holding a charge replace it
AgentOrange is offline
06 636 wont start please help travtagz Mechanical and Technical 1 05-18-2012 03:55 PM
05 636 start up idle 05magna636 Mechanical and Technical 6 05-12-2012 05:28 PM
03 636 will not start 636lee Mechanical and Technical 6 07-10-2011 06:26 PM
03 636 vs. 07 ZX-6R EvilTwin The ZX6R 17 12-14-2010 02:24 PM
06 636 Build Start WalkaWalka The ZX6R 28 12-12-2009 06:27 PM
