03/04/05/06 ZX636 ZX6R speedo upgrade - Page 14 - ZX6R Forum
 30Likes
post #196 of 216 Old 11-19-2018, 07:14 AM
Part arrived in Canada. Part looks very well designed and built. Will be installed next spring as bike is put away for the winter.....
Ducman is offline
post #197 of 216 Old 11-27-2018, 04:44 AM
Hi there
ive a 06 ZX6R, im quite happy with the standard speedo, but could i uses your speedo upgrade as a speed healer on my standard clocks?
thanks, regards Rich
owerr1 is offline
post #198 of 216 Old 11-27-2018, 06:37 AM
@extr400 , I would like to order one of these circuit boards. I have a 06 Zx6R, in NJ. PM sent!
ZX-Ken is offline
post #199 of 216 Old 11-27-2018, 09:56 AM Thread Starter
extr400's Avatar
I Ride: ZX636-05, GSXR-750-L1
@ZX-Ken : reply sent. Thanks for your enquiry.
@owerr1 : Hello Yorkie! Ah, sorry but the adapter connects between the new plug of the 07+ speedo and the old style wiring harness plug on your bike. This wouldn't just plug in between an 06 gauge without modifying the design. Your probably better off just getting a speedo healer.
extr400 is offline
post #200 of 216 Old 11-28-2018, 02:03 AM
LOL @ Yorkie.
thanks for the fast reply
owerr1 is offline
post #201 of 216 Old 12-16-2018, 01:15 AM
laggy311's Avatar
I Ride: Dirty
Got everything set up. 09-12 cluster on an 06. Amazing little device. Thanks you so so much.
My only issue is that 4th gear shows as 3rd. On the upshift and the down shift. 3rd gear shows as 3rd, also. So I never get to 6th. I've tried regular shifting and with quickshifter. High and low rpm. Figured I'd post here, so that nay issue we figure out can get fixed. Sidenote. I do have a speedo healer currently set. I may zero it out and let this adapter have at it!
Also, potentially have a fuel light coming on to soon, although last fillup could have been a touch short.
TBC!
Yo momma so fat, Thanos had to snap twice.
Sitzpinklers
laggy311 is offline
post #202 of 216 Old 12-16-2018, 03:53 PM
laggy311's Avatar
I Ride: Dirty
Update: all good.
Speedohealer was set to -8.5%. It has a bank a and b. B is still defaulted to zero. Apparently the strain was more than the bike could bear lol
So Iím assuming the software will net same results at -8.5% ... we shall see
Sitzpinklers
laggy311 is offline
post #203 of 216 Old 01-07-2019, 02:38 AM
Punchy636's Avatar
I Ride: 2003 ZX6R 636 , 2011 ER6N commuter
Hi all,
Since i am rebuilding a damaged bike, i don't have the bracket that holds the speedo, does anyone know since i am now buying a 2007 onwards speedo, do i buy the 2007 bracket ?? or the 2003-04 bracket ??
If i buy the late bracket, will the mirror ends line up ?
Thanks for any help you can offer.....
Punchy636 is offline
post #204 of 216 Old 01-13-2019, 09:48 AM
Devil7's Avatar
I Ride: 2013 ZX6R 636 ABS
Originally Posted by Punchy636 View Post
Hi all,
Personally i'd get the correct bracket for the bike then make something for the new cluster, i've got an 09 cluster on an A1P zx6r - wasn't difficult , if you buy the 07 bracket you've got a lot of other thing to worry about lining up
Name:	Screen Shot 2019-01-13 at 17.47.29.png
Punchy636 likes this.
Devil7 is offline
post #205 of 216 Old 01-14-2019, 05:09 AM
Punchy636's Avatar
Yeah after thinking about it, i will just leave it, and probably end up making my own one to suit the bike and that cluster once it all arrives as i'm still waiting on fairings, air duct and speedo to turn up from overseas.
Devil7 likes this.
post #206 of 216 Old 01-21-2019, 05:30 AM
Truly plug and play
I finally installed the new tack from a 2009 ZX6R and the interface unit and it was the EASIEST upgrade I have done to my bike. Unhook the OEM harness and tack, replace with the new pc of harness and attach to the new gage and everything worked as advertised....
Thank you for such a well built unit that actually performed as advertised!!!!
Ducman is offline
post #207 of 216 Old 01-24-2019, 01:10 AM Thread Starter
extr400's Avatar
Cheers matey. Appreciate the feedback!
Adapters are still available, however im on my winter break until early March 2019. Will follow up enquiries then.
Hey, everyone's allowed some downtime, right?
RJ2112 and Devil7 like this.
extr400 is offline
post #208 of 216 Old 03-06-2019, 09:09 AM
Phenomenal's Avatar
I Ride: -05 ZX6R 674cc, -92 GSX-R T 1216cc E85
Im gonna need one. Pm me when u are back in business.
Phenomenal is offline
post #209 of 216 Old 03-07-2019, 04:00 AM
RichieNoble's Avatar
Hey bud Iím looking for one of the adapters when are you back?
RichieNoble is offline
post #210 of 216 Old 05-10-2019, 07:08 AM
Phenomenal's Avatar
Got my adapter, works like charm. Superb quality. Recommended!
Parts compatibility list ! Stiggy Mechanical and Technical 176 01-31-2019 05:02 PM
FREE Copies of 05-06 Service Manual ZX6R ZX636 Ninja636XXL The ZX6R 19 10-10-2018 01:57 PM
Kawasaki ZX6R Model Designations Lash The ZX6R 27 10-28-2017 12:33 AM
speedo healer for 2000 zx6r Infi17yte13 The ZX6R 1 07-01-2009 04:22 PM
