ZX6R Forum
-   -   Sprocket setup (https://www.zx6r.com/zx6r/23803-sprocket-setup.html)
bowhunter11 02-27-2012 09:52 PM
Sprocket setup
What sprocket setup are you running? How do u like it? Pros and cons?
cdn ws6 02-27-2012 09:57 PM
DID/ Superlite -1/+2
I can't comment on performance or pros/cons at this point as I installed them just before putting the bike away.
http://i216.photobucket.com/albums/c...1-01173307.jpg
givuhcky22 02-27-2012 11:03 PM
bout to put on 0/+3
THUG 02-28-2012 12:01 AM
Stock and i love it
i can wheelie like a mofo and my top speed (according to speedometer) is 168 mph
best of both worlds
PowerGroove 02-28-2012 12:19 AM
-1/+2 Vortex steel countershaft and aluminum rear.
Pros. Quicker acceleration, very responsive, a little better flickability transitioning from turn to turn due to less spinning mass
Cons. Throttle is a bit choppier but not bad. And top speed is lower. Exactly 150mph at the rev limiter. But I'm at the track going fast usually and never have seen more than about 135 in the long straights before its on the brakes time. Freeway riding is a little crappy just because it's about 8k at 75mph. So a little buzzy and less fuel mileage.
Street Hawk 02-28-2012 01:52 AM
Originally Posted by givuhcky22 (Post 334852)
bout to put on 0/+3
Love those wheelies, uh? :)
Originally Posted by THUG (Post 334884)
Stock and i love it
LIER... Sike, I'm just kidding. :laugh You got me by 5 mph
Alex Gold 02-28-2012 01:55 AM
0/+3 here, seems to me to be the perfect setup!
zx racer 02-28-2012 07:47 AM
-1 +2 here the optimum gearing for the zx6r's.
clwither 02-28-2012 07:51 AM
Newb question. What is the difference inbetween the two sprockets.
I mean obviously there is a front and a rear sprocket. But what will increasing/decreasing each do. I'm assuming + in the rear would equate to quicker acceleration.
Vampyre 02-28-2012 07:59 AM
I believe that - up front and + in back both equate to quicker acceleration. I think -1 up front equals about +3 on rear.
1000RR 02-28-2012 08:08 AM
-1,+6... but this is on a race bike and our track is quite tight/technical.
My suggestion would be to figure out what kinda top speed you're looking for at the end of the day and then go with a sprocket combination that gets you there. You can play around w/all that w/the following link --> Gearing Commander: Motorcycle Speed, RPM, Chain & Sprockets Calculator Most folks believe they want all the top speed they can get, but the reality is most never use the very top (most not all). So think back to your last 10 rides and what top speed would you overall be happy with. If you're looking for all the top speed you can get, well you got the wrong bike to begin with... so be honest w/yourself.
If you want to play around with with a minimal "buy-in", just get you a -1 front and throw it on. It's equivalent to adding about 2.6-ish teeth to the rear. You won't have to change the length of your chain and you're only gonna be out about $25-$30.
09blmonster 02-28-2012 08:16 AM
-1/+2 should have came stock! All I have to say! The best parts I've put on the bitch!
TxBornSooner 02-28-2012 08:34 AM
-1/stock. Lots of people like the -1/+2 not me. It was TOO much. Wasn't smooth enough for me. -1 gives me a lil more torque without it being a track/wheelie type bike.
N0ob Rider 02-28-2012 09:29 AM
I am also going to go with the -1/stock setup
PowerGroove 02-28-2012 09:32 AM
Stock and i love it
best of both worlds
So you're probably only topping out at about 159 due to the speedo error. :)
Going -1/+2 will allow you to use the same chain if you revert back to stock as it's about the same length. Food for thought. :)
You are correct sir!
