Sprocket setup - Page 5 - ZX6R Forum
View Poll Results: What sprockets are on her bike?
Stock 308 51.94%
-1/+1 21 3.54%
-1/+2 177 29.85%
-1/+3 21 3.54%
-1/+4 3 0.51%
-1/+5 4 0.67%
-1/+6 1 0.17%
-1/+7 and up 2 0.34%
-2/+3 1 0.17%
-2/+4 0 0%
-2/+5 and up 1 0.17%
Other 54 9.11%
Voters: 593. You may not vote on this poll
 57Likes
Closed Thread
post #61 of 348 Old 03-01-2012, 08:31 AM
anjos's Avatar
I Ride: 2012 ZX6R, 2002 ZX6R
If going -1 on the front is roughly the same as going +2 on the rear, is there any reason why I wouldn't just go +2 on the rear instead of swapping out the front one? I've been told that swapping the rear is pretty easy, but the front one can be a bit of a pain
anjos is offline
post #62 of 348 Old 03-01-2012, 08:49 AM
636biker's Avatar
I Ride: 2004 ZX6R 636
Going down in the front there is less rotating mass (your rear sprocket doesn't get bigger). Im 1 down in the front right now but just ordered chain and sprockets and went to a -1 front and +1 rear
2004 636
Custom shorty devil Slip on/ K&N Filter/ Power Commander USBIII/ -1 +1 sprockets/ Hyperpro steering stabilizer/ 09+ rotor swap/ Zero Gravity wind screen/ Integrated tail light/ flush mount turn signals
636biker is offline
post #63 of 348 Old 03-01-2012, 08:54 AM
anjos's Avatar
So going -1 in the front, I can use the stock chain, right?
anjos is offline
post #64 of 348 Old 03-01-2012, 08:57 AM
6OTM Master of Ceremonies
Youssef636's Avatar
^yes but mass majority will tell you get a new chain as well ....a -1/+2 will also work on a stock chain
Winner - 6OTM March 2012
FAQ for new riders
Youssef636 is offline
post #65 of 348 Old 03-01-2012, 09:15 AM
1000RR's Avatar
I Ride: '09 ZX6R - Race Bike
-1 on the front is closer to a +2.6 or 2.7 on the rear. Swapping the rear is easy, the front isn't too bad either.
Actually, from a rotational mass perspective, most folks go with an aluminum rear sprocket which is a lot of rotational mass savings back there. More-so than dropping one tooth in the front... plus with the front being so small (diameter), the resulting affects are not as great. So even though you are getting a bigger rear for all of this, it is still much lighter (assuming it's aluminum) than the stock steel rear sprocket.
Yes
____________________________
HUGE Thanks to my Race Sponsors!!
Riders Discount**PMtec, Inc**Schuberth Helmets**DrippinWet**Brentwood Barber Shop**MOTUL**MRRF-Road Racing Forum**Leatt Neck Protection**Knecht Automotive
Motorcycle Racing - Because basketball, baseball, football, and golf only require one ball!
1000RR is offline
post #66 of 348 Old 03-01-2012, 09:41 AM
636biker's Avatar
I ordered a steel rear because my aluminum one didnt last for shit!! I supposed less wheelies might help but there too much fun
2004 636
636biker is offline
post #67 of 348 Old 03-01-2012, 09:44 AM
Aeon87's Avatar
I Ride: 2003 SixDirtySix, 2006 SixDirtySix
Only -1 up front for me.
2007 EX250 (sold)
2007 Suzuki SV650 (totalled)
2004 Buell XB12R (sold)
2007 Suzuki GSXR-600 (traded)
2006 Buell XB9SX (sold)
Current Rides:
2006 Kawasaki ZX-6R (636)
2003 Kawasaki ZX-6R (636)
1989 Chevy Silverado 1500 5.7L
Aeon87 is offline
post #68 of 348 Old 03-01-2012, 09:48 AM
1000RR's Avatar
Could very well be... They actually make a combo steel/aluminum I've seen that looks interesting. It's a two piece rear that has steel teeth and the part closer to the hub is aluminum.
I run an aluminum one on my S1000RR and haven't really had issues, but I tend to change out chains/sprockets more often anyway. Race bikes hold the aluminum rears as well, any acceleration assistance out there is always welcome.
1000RR is offline
post #69 of 348 Old 03-01-2012, 09:56 AM
636biker's Avatar
Interesting... who makes this combination sprocket? Yeah just thought I would go back to a steel rear just bought my first house so money cant fly out of my pocket like I used to let it
2004 636
636biker is offline
post #70 of 348 Old 03-01-2012, 10:00 AM
1000RR's Avatar
Supersprox
1000RR is offline
post #71 of 348 Old 03-01-2012, 10:23 AM
636biker's Avatar
Supersprox
thanks!
2004 636
636biker is offline
post #72 of 348 Old 03-01-2012, 01:54 PM
nexia201's Avatar
I Ride: zx6r 636 04
i have stock front +6 rear and found that its the best , had -1 +2 and -1 +3 and -1+6 but this is best setup so far
nexia201 is offline
post #73 of 348 Old 03-01-2012, 01:57 PM
nexia201's Avatar
I Ride: zx6r 636 04
its not just being a bit of a pain its more chain consuming too because the chain has to turn on a smaller radious because of the smaller front pulley and get more wear and tear
nexia201 is offline
post #74 of 348 Old 03-01-2012, 02:16 PM
Gav179's Avatar
I Ride: 2010 ZX10R
I run a -1 renthal front sprocket and a stock rear wich as i agree with others its just right to liven it up a little, but i also use a 1/4 turn quick action throttle
-1 front is the equivalent to +3 on the rear
2009 ZX10R
* Tailtidy * Dark tint D/B airflow screen * HEL braided lines * Pazzo replica levers
Gav179 is offline
post #75 of 348 Old 03-01-2012, 06:54 PM
MDeezy's Avatar
Yes
Okay...I'm a sproket noob but let me see if I got this right.
Stock sprockets are a heavy steel or some other material correct?
Getting aftermarket aluminum sprockets would help reduce rotational mass which would help with acceleration.
How is the bike affected if you change just one sprocket?
I imagine changing the front would help with quicker acceleration but what does changing the rear do?
Does this affect gas economy? or not really as it doesn't affect the gearing and its still all based on how you are with the throttle?
Since the stock sprockets are of a heavier thicker metal material, i'd imagine they last a lot longer. Since aftermarket stock ones are aluminum I'd imagine their lifespan is half?
I mainly stayed away cause I figured it would affect gas econ, especially since I use mine for commuting in addition to fun.
05 ZX6R - Samantha...PUIg Black Double bubble|| Random frame sliders| Morimoto Dual Bi-Xeon Retrofit with 35w 6k HIDs| more to come...
MDeezy is offline
Closed Thread
What setup should I use ? thewild1 The ZX6R 14 08-02-2012 06:51 PM
removal front sprocket - zx6r 636 a1p 2002 thegreensnot Mechanical and Technical 21 01-31-2012 04:28 AM
WTB 03-04 ZX6R Sprocket carrier & 520 sprocket crofty7 Want to Buy 3 12-28-2009 01:29 AM
