Cooling fan not working - ZX6R Forum
post #1 of 17 Old 08-27-2011, 03:18 PM Thread Starter
Ok so I recently had to replace my radiator and now my radiator fan wont turn on. Ive hooked up a multimeter to the connector and it shows a reading of 14.5 volts when the tempature gets over 215 but the motor wont start working. It doesnt show a reading when the temp is below 215. Ive even hooked up a spare fan that I have and that one doesnt work either. Need some help??
Twista89 is offline
post #2 of 17 Old 08-27-2011, 03:35 PM
hdasilva1990's Avatar
I Ride: 2006 Custom Orange ZX6-R 636
check the ground.. been runing into issues with ground wired up here in the shop latley
Originally Posted by givuhcky22 View Post
i like hearing "hey, were you riding at like.. midnight last night? you woke me up."
"loud pipes save lives" ...and cause sleep deprivation.
Photo Album
hdasilva1990 is offline
post #3 of 17 Old 08-27-2011, 03:39 PM Thread Starter
how should i go about doing that...sorry not really good with electricals yet...
Twista89 is offline
post #4 of 17 Old 08-27-2011, 04:02 PM
mtp
mtp's Avatar
when i was faffing on with mine i blew the fuse you might not of heard it pop but have a look there to
ZX6R, 97 plate streetfighter on the road, home made roll cage... GSXR 1100 streetfighter project, busa swing arm, ZX6R seat unit subframe home made, top yolks home made etc etc
mtp is offline
post #5 of 17 Old 08-27-2011, 04:25 PM
hellonearth's Avatar
I Ride: '17 ZX10r
yea its probly a fuse
Unreal. I love dick very much and this is the kind of consideration I get?
P model spark plug change! http://www.instructables.com/id/2008...k-Plug-Change/
hellonearth is offline
post #6 of 17 Old 08-27-2011, 04:35 PM Thread Starter
checked the fuse and it was normal, like i said when i hooked up my multimeter to the connector piece it showed 14 volts going through it so all the way up to the connector it gets power. I tried hooking up my extra fan to my car battery and it didnt turn on. I didnt try the fan hooked up on my radiator yet though but im pretty sure both of these fans are good because the one on my bike worked fine before i did the radiator swap and the one the guy sent me worked fine before he took it off his bike to send it to me....
Twista89 is offline
post #7 of 17 Old 08-27-2011, 07:01 PM
TheEvilTwin's Avatar
I Ride: ZX6, ZX10, BMW
When you checked the voltage at the plug for the fan. Did you go from one terminal on the plug to the other, or from one terminal to ground (frame, bolt, etc)? Make sure you go from one terminal to the other. Some bikes always have voltage at the fan and close the ground circuit to bring the fan on.
CCS 132 Proudly sponsored by Amsoil, DC-MOTO.net, Manassas Honda Kawasaki and MARRC
2014 #1 RCGT, #2 MWSB, 2014 Sportsman Award, 2013 Amateur of the Year, 2012 Cornerworker of the Year
Follow Motosylum Racing
R6- Bonnie the Pirate 6
R100rs- 66k and counting!
R1200 GS/A- The moose is loose!
KTM 400 XCW- Riding dirty!
TheEvilTwin is offline
post #8 of 17 Old 08-27-2011, 08:57 PM
ZoomSplat's Avatar
so you hooked a spare fan up to a spare battery to see why the one on your bike isn't working? Can we please get a face palm, and a forceful one at that.
When you say you hooked your multimeter up to the connector, how did you do it and what was it set to? Put power directly to the fan and see if it turns on. if not, then your fan motor isn't working. Also, make sure that your cooling system is full, if you get a bubble where the sensor is then the ECU won't know that its hot so it won't turn the fan on.
ZoomSplat is offline
post #9 of 17 Old 08-28-2011, 01:51 PM Thread Starter
even if im getting a temp reading on the display. And what I did was hooked my multimeter up to the connector, one lead on the postive wire and one on the negative wire i didnt ground it to the chasis. The connector wouldnt show a voltage until the temp reading got over 215 then it would show 14 volts on the connector.
Twista89 is offline
post #10 of 17 Old 08-28-2011, 05:01 PM
DaddysNinja's Avatar
If you can hook up the fan directly to the battery then you will know if the fan is good or not. You said you got 14 volts at the plug. What did you ground to? Does your meter have a ohm setting? Find the negative wire inside the plug and put one probe on it then put the other probe to the motor mount bolt. It should ring. If it doesn't then you lost what is known as a common ground. But before you do all that do like I said with the fan motor first. It is usually the issue, and it is possible to have two bad fans. Tell me what you find and let's take it from there. Good luck.
Nil conscire sibi
SOLD 2007 ZX6R 03/29/2013
Only once.
Originally Posted by SkyChimp
DaddysNinja is offline
post #11 of 17 Old 08-28-2011, 06:12 PM Thread Starter
what should i do if the fan doesnt have a common ground I plugged the fans up to the battery and they didnt turn on....but honestly they both worked before i did the swap...there should be no reason for them to just quit when i reinstall my radiator....especially both of them....
Twista89 is offline
post #12 of 17 Old 08-28-2011, 07:39 PM
If that battery has a charge those fans should spin. If they didn't spin then yes both fans are bad. Unless maybe you are doing something totally wrong. I don't know what else to say bro. Being that you have power at the plug I really just don't think that is the issue. I would focus on the fans being shot. I would buy a new fan and go with that. But at this point without the bike in front of me I am like Stevie Wonder man. Lol.
Nil conscire sibi
Only once.
post #13 of 17 Old 08-28-2011, 08:25 PM
TXZX6R's Avatar
I Ride: 02 ZX6R
Just ni**er rig it, like i did and run your fan to a toga switch!
Originally Posted by LenaLilLower View Post
Hahahaha....there's never a wrong time to suck a cock!! +1000000
THE ONLY THING BETTER THAN MY ZX6 IS HUGE BOOBS AND TATTOOS!
Vortex front & rear sprockets -1/+5 with 520 conv.-- EK Gold Chain-- Myrtle West lowering links (2.5in drop)-- Myrtle West 6in swingarm ext.-- matte black paint-- custom blinkers-- sportech wscreen-- D&D exhaust-- nut sack hanging from under tail (for humor)
TXZX6R is offline
post #14 of 17 Old 08-28-2011, 10:08 PM
ZoomSplat's Avatar
if you go dirrectly from the battery to the fan, with nothing in between but the two wires that YOU put there, and the fan does not come on, then the fan motor is broken and the fan needs to be replaced.
What year is your bike that it has two fans?
post #15 of 17 Old 08-29-2011, 05:20 AM
I don't think he has two fans on the bike. I think he has two separate fan units and both are bad.
Nil conscire sibi
Only once.
My fan stopped working, oh noooooo Lefix Mechanical and Technical 8 02-15-2012 09:03 PM
FI code 56 Radiator Fan relay open or short problem.... katanaram Mechanical and Technical 2 09-27-2011 10:14 PM
Help with radiator fan 2011 ZX6R ZXNasty Mechanical and Technical 3 07-22-2011 08:34 AM
07 zx6r fan/ cooling problem!! joelh82 Mechanical and Technical 15 04-29-2011 08:16 AM
Has to be something with the fan. ZX636 The ZX6R 5 05-08-2009 09:05 PM
