Flat spot :confuses: - ZX6R Forum
post #1 of 18 Old 04-09-2011, 01:44 PM Thread Starter
zx6chris's Avatar
I Ride: whats left of a j1
As above iv got a flat spot at about 3500 rpm it's the same in every gear if I am in traffic at about 60 and open it up if I'm at about 3500 it bogs down some times I can ride through it if the gear is low enough I've had the carbs balanced and they are plugs all the plugs are ok it rides fine apart from that oh it also kicks at about 10500 rpm almost like a stroker dose with a power band
its not what u know its who u know!!
zx6chris is offline
post #2 of 18 Old 04-09-2011, 02:25 PM
arron's Avatar
I Ride: 1998 zx6r, 1999 sv650
What mods have you got? Migh need a jet kit or lube the throttle cables? Mine used to have a flat spot till I went to the next highest gas octane on the pump..
still lovin forever!
arron is offline
post #3 of 18 Old 04-09-2011, 02:42 PM
I Ride: 2006 kawi ninja 636
i would say if you have any mods like exhaust or after market filter you may need a jet kit to solve your issue with the flat spots your having.
bluebeast06 is offline
post #4 of 18 Old 04-09-2011, 06:08 PM
raized1199's Avatar
+1 on the jet kit.
And honestly,
I got rid of my flat spot on my 01 by using...
in every fill up.
Around here, 10% ethanol is in every pump.
My bike calls out for 91 octane to began with
and finding higher is tough.
So I took a chance and it worked for me.
There will be those that will argue to facts on
higher octane and the Sta-bil both.
But, it worked out well in my bike.
I installed an ignition advance also (+4) about
a year before I started using the Sta-bil and
that cleared it up most of the way.
Then the marine Sta-bil cleared up the rest.
I did not want to spring for a jet kit, so I was
looking for an alternative. lol
Good luck.
You might go ahead and look into synchronizing
your carbs if it has not been done in a while too.
Remember...
are also timed for 70 mph.
-->Urban Assault Vehicle<--
raized1199 is offline
post #5 of 18 Old 04-09-2011, 06:33 PM
arron's Avatar
Every petrol station around here has 3 kinds of petrol, e10-91 and preium petrol.
arron is offline
post #6 of 18 Old 04-10-2011, 03:51 AM Thread Starter
zx6chris's Avatar
It had it from the start iv had it about a year almost and it had the standard can on it and it was quite bad but since I put the scorpion on with no baffles at all it's a bit better iv not tried higher octane fuel but I'll give that a go It's also got a stock air filter
zx6chris is offline
post #7 of 18 Old 04-10-2011, 11:51 AM Thread Starter
zx6chris's Avatar
Originally Posted by raized1199 View Post
+1 on the jet kit.
And honestly,
in every fill up.
Good luck.
iv had the carbs balanced and they were spot on
zx6chris is offline
post #8 of 18 Old 04-11-2011, 08:03 PM
ZoomSplat's Avatar
Why are you riding with the RPM's that low to begin with?
ZoomSplat is offline
post #9 of 18 Old 04-11-2011, 09:03 PM
raized1199's Avatar
lol
..oh, sorry.
Remember...
post #10 of 18 Old 04-11-2011, 11:43 PM Thread Starter
zx6chris's Avatar
Cos I'm just going with the flow of traffic it dose it even if I pull away with a big hand full of gas and if I pull a way Normaly just taking it steady it's even worse
zx6chris is offline
post #11 of 18 Old 04-21-2011, 01:01 PM Thread Starter
zx6chris's Avatar
right iv had a go with the higher octane fuel and its better but its still there iv looked at some of that sta-bil stuff well the type we have over here just seems a lot of mone each time i fill up
zx6chris is offline
post #12 of 18 Old 04-22-2011, 10:43 AM
landspeeder's Avatar
I Ride: 2006 ZX-6rr/2008 ZX-10R/2008 EX-250R
Cleaned or changed your air filter lately? It sounds like simply changing the needles to a taper that is right for your bike at that rpm would do it. Figure out if it is fat or lean at that rpm. If the rest of the rev range is good look for a needle to with the taper to fix that area only.
[email protected]Worlds Fastest Normally Aspirated 650cc Class Land Speed Motorcycle on the mile at 184.161 mph, on the 1.5 mile at 190.118 mph and street legal at 182.095 mph.
landspeeder is offline
post #13 of 18 Old 04-22-2011, 11:28 AM Thread Starter
zx6chris's Avatar
yeah i cleaned the filter it now seems to be at about 5000 rpm that it bogs down and thats with the higher octane fuel
zx6chris is offline
post #14 of 18 Old 06-06-2011, 10:32 AM Thread Starter
zx6chris's Avatar
right iv had this flat sopt and its been getting worse and worse to the pointwhere i was pulling a way on a small up hill and it just stalled i started it and it ran fine also the flat spot has got bigger and strugles right up till 7000 rpm all iv been able to do is change the plugs and put the stock end can back on not had the chance give it a long run
zx6chris is offline
post #15 of 18 Old 08-17-2011, 07:50 AM Thread Starter
zx6chris's Avatar
It's finally gone at last pulls all the way up through the revs and dosnt big down at all now It's like a new bike and I'm loving it
zx6chris is offline
Complete Flat Candy Blue Metallic 06 Fairing? SadbutTrue Mechanical and Technical 8 01-24-2012 05:46 PM
zzr1400 flat out scoobs Videos 1 01-24-2012 10:05 AM
Flat spot / stuttering 6 - 7.5K chrsjcb Mechanical and Technical 58 12-17-2011 05:30 AM
Flat Rear Arlo_007 Motorcycle Talk 7 05-02-2011 08:12 AM
flat spot on front tire?? hocknscary87 The ZX6R 1 04-09-2009 07:34 PM
