Power commander 3usb- unable to start engine - ZX6R Forum
post #1 of 24 Old 03-08-2011, 10:20 AM Thread Starter
Orkin's Avatar
I Ride: 2016 ZX6R-636
I loaded the map and installed my new PC3 to my 2006 zx6r yesterday afternoon. After the installation, I was able to start the engine without problems and it seemed to be working fine (50 degrees of). This morning (30 degrees) when I tried to start the engine it made pop sounds. I assumed it was because it was just warming up then it stalled. I was unable to start the engine again (battery is in good condition). I would really appreciate your advice.
Orkin is offline
post #2 of 24 Old 03-08-2011, 11:58 AM
zx racer's Avatar
I Ride: 04 ZX636
check over the installtion and make sure you have the connectors on the pc going to the right place. also wat map did you got download into the pc ?
zx racer is offline
post #3 of 24 Old 03-08-2011, 12:14 PM
tommyszx6rr's Avatar
I Ride: 2006 ZX6RR
It's a pain, but can you take the PC off & see if it will start? Sounds like the map you loaded advanced the hell out of your timing!
06 ZX6RR Hotbodies Undertail, Solo Seat, & Hugger. PC3, Speedo Healer, Ivan's Servo Elim, European Jump, Cams Dialed In, Racing Head Gasket, K&N, 520 Gear Swap, Sportech Windscreen, Clear Alternatives.
tommyszx6rr is offline
post #4 of 24 Old 03-08-2011, 01:11 PM
You most likely missed a connection. Happened to me two weeks ago putting one on a buddies cbr1000. Actually one of the pins bent, which is why it was not making the connection.
Either way good luck man.
j0ntar is offline
post #5 of 24 Old 03-08-2011, 01:40 PM Thread Starter
Orkin's Avatar
ZX Racer
Because I didn't find the map for the Yoshimura RS-5 slip on, DynoJet sent me the following email:
"on Our predeveloped map #M218-008 ( Akrapovic slip-on exhaust Sotck or aftermarket filter) is the closest to your setup that we currently have available in our map database library. The air flow characteristics between the two setups should be similar enough for the map to work for you as a starting point You also always have the option to have the bike dyno tuned and custom mapped specifically for your bike's setup and or riding style if you like at one of our approved tuning centers in your local area if you want to get it 100% optimized.
Thank you all for the advice. I will go over the installation process again.
Orkin is offline
post #6 of 24 Old 03-08-2011, 04:51 PM
zx racer's Avatar
I Ride: 04 ZX636
Originally Posted by Orkin View Post
ZX Racer
yea most of all the dj slipon maps are the same. just download the closest map you see for your mods and try that. it should get you pretty close or if you want you can have the bike dyno tune. most shops charge around 250-300 bucks tho. but check the installtion and plugs and make sure you didnt plug one up in the wrong place ive seen people do this hundred of times.
zx racer is offline
post #7 of 24 Old 03-08-2011, 05:57 PM Thread Starter
Orkin's Avatar
I just tried the map suggested but the bike didn't start. I will take the PC3 off and hope it will start again. Also, I hope I didn’t mess up the engine
Orkin is offline
post #8 of 24 Old 03-08-2011, 09:57 PM
I Ride: 2006 ZX6RR
I just tried the map suggested but the bike didn't start. I will take the PC3 off and hope it will start again. Also, I hope I didnít mess up the engine
My 06 RR needs to be running before the map will load. Same deal for the R's correct?
post #9 of 24 Old 03-09-2011, 07:37 AM Thread Starter
Orkin's Avatar
Many Thanks guys,
I went over the installation again and I found out that I plugged the cables in the wrong order. This forum ahs been very helpful
Orkin is offline
post #10 of 24 Old 03-09-2011, 07:54 AM
I Ride: 2006 ZX6RR
Glad to hear you got it sorted!
post #11 of 24 Old 03-14-2011, 03:10 PM
PHo
PHo's Avatar
I Ride: 2005 ZX6R GREEEEN
nice, sounds like another prob fixed by the forums woot!
What parts you got on your bike?
Ive got a Yoshi RS-5 with K&N Filter and I got a custom map, I dunno whether you'd wanna try that?
'Only when we are no longer afraid do we begin to live'
| 2005 ZX6R C1H // Yoshi RS-5 Carbon / K&N / PCIII + Custom Map / Sprint SXC Damper / Harris Crash Bungs |
| 1992 GPZ500 EX500A // Nexxus Can / Custom 'Distressed Look' Panels |
| 2002 Honda S2000 AP1 // Grille-Guys Front Grills |
PHo is offline
post #12 of 24 Old 03-14-2011, 04:58 PM Thread Starter
Orkin's Avatar
I got the same yoshi RS-5 slip on with a K&n filter. I would like to try the map you got. Thanks
Orkin is offline
post #13 of 24 Old 03-15-2011, 05:14 AM
PHo
PHo's Avatar
ok sweet well give me today to try and get the map off and ill get it to ya
PHo is offline
post #14 of 24 Old 03-15-2011, 05:52 AM Thread Starter
Orkin's Avatar
thanks PHo, I really appreciate that.
Orkin is offline
post #15 of 24 Old 03-27-2011, 05:41 AM
PHo
PHo's Avatar
hey orkin, im sooo sorry its taken so long but been a bit busy.
anyhow I got the map off my bike just now. Gimme an email and its yours.
Ill also send you a picture of the power/torque graph printout I got from the shop.
PHo is offline
Power commander 3 rob56789 Mechanical and Technical 6 01-31-2012 03:33 AM
03 zx6r and power commander III USB Myrddin33 Mechanical and Technical 0 07-25-2011 04:02 PM
Alternatives to Power Commander... Markchouinar The ZX6R 13 02-28-2009 02:19 PM
