Advice Zx6r ! Rebuilt Engine Not Running Right ! - ZX6R Forum
post #1 of 4 Old 11-16-2009, 11:53 AM Thread Starter
Just rebuilt complete ZX6R J model engine . started it up today 4 the 1st time the engine is sweet no rattles etc.But this is were i could do with some advice ,(please only reply if you are clued up with engines ) The bike wont run WITHOUT full choke also i can only rev it upto 4000rpm before it trys to cut out, I know its a fuel problem but as severe as needing full choke all time is more than a tweeking of the carbs,could a bad plug not firing correct (weak)under compression cause this,There is nothing ,nothing wrong in the line of vacuum every thing is piped right. Its not the timing not cylinder head valve leakage all hardware is new and within tolerance of service limit
mick1275 is offline
post #2 of 4 Old 11-16-2009, 05:03 PM
mityaz's Avatar
are you sure the choke cable is connected right? look at the carbs and see if the cable pulls the jets open when you pull the choke
mityaz is offline
post #3 of 4 Old 11-17-2009, 01:47 AM Thread Starter
course it is m8 gona have a look at plugs ive a feeling its a plug but time will tell in a few hrs
mick1275 is offline
post #4 of 4 Old 11-17-2009, 05:37 AM
ZoomSplat's Avatar
is it cold where you are? could be a jetting problem, and the choke is compensating for it. My dirt bike was doing the same thing until last weekend when I bumped the metering needle up one notch ritcher, adjusted the throttle stop to compensate, and now it runs perfect.
ZoomSplat is offline
Parts compatibility list ! Stiggy Mechanical and Technical 178 10-03-2019 04:01 PM
Kawasaki ZX6R Model Designations Lash The ZX6R 27 10-28-2017 01:33 AM
09-11 ZX6R headers advice needed Gav179 Mechanical and Technical 8 02-04-2013 07:54 AM
Stripped engine oil nut hole. Advice. basick The ZX6R 27 10-28-2009 04:44 PM
