Harbor Freight Wheel Chock - ZX6R Forum
 7Likes
  • 2 Post By zx6rguiy
  • 1 Post By WildCard
  • 1 Post By zx6rguiy
  • 1 Post By Strider
  • 2 Post By jimundascores
post #1 of 9 Old 01-14-2020, 07:50 AM Thread Starter
Newyork's Avatar
So I recently inherited a sweet 06 E250 with 53k miles from my father in law who passed
in October. So I plan to mount two staggered TRS systems inside and was considering the HF wheel chocks for the fronts. I thought there were posts but couldnít seem to find ones that talk about the chock so I wanted to see who
,If anyone, uses one.
Also if anyone has mounted TRS into an e250 your input would be appreciated.
https://www.harborfreight.com/1800-l...hoCEngQAvD_BwE
May 2018 ZX6R of the Month
Newyork is offline
post #2 of 9 Old 01-14-2020, 07:53 AM
I Ride: '12 ZX6
Zero need for a wheel chock for the front if you're using the TRS, and to use that setup would render it bike specific for the situation, as the wheelbases between bikes could vary enough that the wheel chock may be too short or far away while secured in with the TRS.
WERA Expert #37
N2 Track Days Control Rider
'07 ZX6
Sportbike Track Gear
Woodcraft
Andrew Swenson Design
N2 Track Days
Otto Man is online now
post #3 of 9 Old 01-14-2020, 09:13 AM
zx6rguiy's Avatar
To make more space in the front of the van, sometimes I would mount the TRS underneath the bike. This would put the rear wheel very close to the back door. I didnít do it very often as it is a pain to install it like that. But extra space becomes hard to find when you have 2 bikes.
zx6rguiy is online now
post #4 of 9 Old 01-14-2020, 09:52 AM Thread Starter
Newyork's Avatar
My original plan was to mount one chock up against the drivers seat so the front doesnít move (I have a TRS in my trailer already and the front moves without the chock which is why I want one). And then mount the other TRS near the back door for the second bike.
Definitely considering not using a second chock for the second bike and just stacking my gear bag against it so it doesnít move.
Itís the longer 250 so Iím hoping it will work.
Newyork is offline
post #5 of 9 Old 01-14-2020, 11:40 AM
zx6rguiy's Avatar
If your concerned about the front moving around, why not use a ratchet strap to tie the front down? Like Otto said, the TRS is not designed to need a wheel chock and unless you use a ratchet strap with the wheel chock, I donít see how that would help at all. Iíve had the exact same setup before. Turning the handlebars to full lock will help keep it from moving around.
Otto Man and Strider like this.
post #6 of 9 Old 01-14-2020, 01:55 PM
WildCard's Avatar
I have one that I bolt to my trailer when hauling the bike. It works okay and is pretty well built for the price. It is quite large though and will take up some space. You would probably be better off with a smaller chock in a van.
Newyork likes this.
( ē_ē)
( ē_ē)>⌐■-■
(⌐■_■)
Roads. ☢
WildCard is online now
post #7 of 9 Old 01-14-2020, 07:42 PM
zx6rguiy's Avatar
This was my old setup. Yes, I understand its a little unorthodox to mount the bike on the wall. But hey, its not stupid if it works.
Edit: For some reason these photos are sideways on my laptop and right side up on my phone.
Newyork likes this.
post #8 of 9 Old 01-15-2020, 01:43 AM
Yea, with the TRS you shouldn't need a wheel chock at all (maybe a ratchet strap for the front as mentioned above).
For our trailer hauling setup (we didn't have TRS at the time), we used a different HF wheel chock with great results: https://www.harborfreight.com/motorc...ock-69026.html
Newyork likes this.
post #9 of 9 Old 01-16-2020, 04:58 PM
jimundascores's Avatar
I mounted a baxley chock in a position to steady the front while the bike was locked into TRS. Waste of time and money, not to mention a couple of holes in my trailer that don't need to be there.
Strider and Newyork like this.
jimundascores is offline
