Stator problem - ZX6R Forum
 8Likes
  • 1 Post By Strider
  • 1 Post By riverszzr
  • 2 Post By PowerGroove
  • 3 Post By Jasona25
post #1 of 10 Old 11-17-2019, 09:06 PM Thread Starter
Jasona25's Avatar
Stator problem
I have a 07 zx6r staying on charge will start then after it shuts off the bike will not start back sounds like a dead battery jump and the same thing the lights dim down while running need help asap has a new battery
Jasona25 is offline
post #2 of 10 Old 11-17-2019, 10:37 PM
Hello and welcome!
It sound like you have one or more of the following three problems:
  1. Bad battery
  2. Bad stator
  3. Bad regulator/rectifier
I'm attaching the section of the service manual that shows the procedure for testing each of these components to figure out which one(s) are the problem.
Scorpi0 likes this.
post #3 of 10 Old 11-18-2019, 04:16 PM
At this point all 3 most likely..........
post #4 of 10 Old 11-18-2019, 04:49 PM
you could do like me, replace the battery Fixed? No! replace regulator. Fixed? No! Look at stator, OH it has a burned coil!!! Replace stator life is good - anyone need a good regulator for a FZ6? :-)
Get a voltmeter, check voltage when running. If it's not 14.5 to 14.7 at 4,000RPM you probably have a regulator problem. That's the very simple diagnostics. Best way is to take a bit of time and systematically check your system. There are some good threads that tell how.
As for me I have an Electrical Engineering degree and therefore don't need to do systematic troubleshooting or read manuals. :-)
For my current bike I needed a USB outlet so bought one off Amazon that has a built in voltmeter. Nice as I can tell it on and also see the voltage so will get an quick indication something isn't right with my electrical system. It's handy for keeping my phone charged while using it for navigation and charging my GoPro.
PhotoAl is offline
post #5 of 10 Old 11-18-2019, 07:35 PM
The regulator limits the maximum D.C. Voltage which can be put to the battery..... Too high, and the electrolyte boils away. That's why you should never see more than 14 and change. 16, regulator is bad.
There are a number of reasons the measured voltage may be low, at the battery.
1) The alternator may be damaged, and isn't producing enough current to make the voltage.
2) there may be too much resistance to allow enough current to flow to make the voltage.
3) there might be too many things drawing power, which drops current flow to the battery, resulting in low voltage.
I 've always liked amp meters to indicate what is going on with a charging system, much more than measuring voltage. Easy to watch the battery recharge.... More current flow at first, dropping off as the battery approaches capacity. Discharge is always shown as negative flow.
Odds are good your stator (part of alternator) is burnt and has shorted out so it can't produce enough current.
The underlying question, is why? Nothing sucks more, than making the same 'fix' repeatedly.
It might have reached end of life and simply worn out. That wear can be accelerated dramatically, by shorts, or excessive load.
A multimeter will aide in sorting through the possibilities.
Words to live by
post #6 of 10 Old 11-19-2019, 05:44 AM
Blatent self promotion.
RJ2112 and Strider like this.
PowerGroove is offline
post #7 of 10 Old 11-24-2019, 10:51 PM Thread Starter
Jasona25's Avatar
So I took the battery and had it tested and charged its holding a charge when they done the load test it show weak but for now the bike is starting and running good I bought it from a guy and he said the stator was bad I guess he didn't charge the battery or ride it enough haven't had anymore problems yet
Jasona25 is offline
post #8 of 10 Old 11-25-2019, 12:53 AM
Always best to use numbers to make decisions...... The multimeter is a cheap and effective way to know for a fact, that you won't get stranded somewhere.
Words to live by
post #9 of 10 Old 11-25-2019, 01:00 AM
So when they load tested it.......... did they load test it at what CCA? if they tested it like it is a car battery of course it would fail
they should have turned the machine down to about 125cca
And okay, so the battery will hold a charge statically, but when the bike is running.......... is it charging the battery or no?- you say the previous owner said it has a bad stator, so put a voltmeter on the running bike and see what it says.......duh
battery................marginal or weak battery- replace!
stator..................would be the next item on the list....... bulletproof testing procedure- you know instantly it is either good or bad- reg/rect...............also you can just look at them and 99% of the time tell if it is good or bad
regulator/rectifier would be the last item on the list becasue even brand new ones routinely fail testing and bad ones routinely pass testing
So with serious lack of any information and testing by you.......... who knows- it could strand you in 5 miles or it may be fine for 5 months
post #10 of 10 Old 11-28-2019, 02:48 PM Thread Starter
Jasona25's Avatar
I'll be buying the meter today to finish testing it to be sure but just to be safe I have a new stator and reg/rec to replace the old It has still been running fine since the battery charge but I'm gonna make sure everything is working as it should
RJ2112, Duc995 and Strider like this.
Jasona25 is offline
