Gasket Maker vs. OEM/Aftermarket Gaskets - ZX6R Forum
View Poll Results: What do you use for engine cover gaskets?
RTV/Gasket Maker 1 25.00%
OEM Gaskets 3 75.00%
Aftermarket Gaskets 0 0%
Voters: 4. You may not vote on this poll
  • 1 Post By Brandon35
  • 1 Post By capitalcrew
  • 1 Post By Scorpi0
post #1 of 11 Old 08-16-2019, 10:51 AM Thread Starter
Brandon35's Avatar
Just generally curious what most folks here use for their gaskets on clutch covers and other engine covers. I personally used to buy Cometic gaskets and they worked great, but with the amount of times I would find myself taking off covers and going through gaskets, I turned to a red high temp RTV and never looked back. A bit of a mess if you're not careful, and the prep and wait time is increased, but I find that it generally seals just as well as an OEM/Cometic gasket and at a fraction of the cost.
Brandon35 is offline
post #2 of 11 Old 08-16-2019, 11:22 AM
Oem or cometic. Would want any of that other gunk to find its way into the engine.
JL99
post #3 of 11 Old 08-16-2019, 11:30 AM Thread Starter
Brandon35's Avatar
Haven't had that issue so far. I think people tend to over-do it and that's where all the excess comes from. You're "supposed" to only hand-tighten after applying and wait an hour before torquing and then another 24 hours before filling with oil or fluid. Although I'm sure different brands are slightly different in cure time.
Scorpi0 likes this.
post #4 of 11 Old 08-16-2019, 12:05 PM
capitalcrew's Avatar
Woof. Real gaskets, always.
riverszzr likes this.
Originally Posted by laggy311 View Post
You should try a butthole scanner. I heard everyone has a different starfish like a thumbprint! Just put your asshole to your phone. Its already in position since you spew shit all over it on to this forum.
I don't always scroll right past a post, but when I do, it's usually a half page from rivers.
Badger is probably getting his fap on to all you guys' pics. With his left hand, because hes a hardcore liberal.
No one smashes my shit-pussy. Iím on top.
Originally Posted by capitalcrew
Need moar dicks in muh facehole!!!!!
capitalcrew is offline
post #5 of 11 Old 08-17-2019, 09:28 PM Thread Starter
Brandon35's Avatar
I'm interested in your take on RTV/gasket maker
post #6 of 11 Old 08-17-2019, 10:44 PM
Ive used Gasket Maker with no issues. I think it creates a better seal. Does a better job of filling in the tiniest of imperfections.
Like Brandon said: Dont squirt too much of it. Mate surfaces together and let it sit for an hour before torquing it all down.
Brandon35 likes this.
Scorpi0 is online now
post #7 of 11 Old 08-18-2019, 02:42 AM
If the OEM designed a part to be installed with a gasket..... I use a gasket. The right gasket.
When the shop manual says use a gasket and sealant, I do that.
The crushable nature of the gasket is what is intended to fill the imperfections in the mating surfaces.
Liquid gasket material may work; there's too much variability in that for it to sound like a good idea to me. As a short term, redneck band aid, sure...... Taking apart things glued together, then baked..... That can create more issues later.
post #8 of 11 Old 08-18-2019, 08:25 AM Thread Starter
Brandon35's Avatar
I’m just a cheap bastard at the end of the day and if I dont have leaks I’m okay with using a razor blade to scrape away old material. I havent seen any leaks on my engine covers when I’ve done it but again, I use a high temp red RTV so it may just be the stuff I use
post #9 of 11 Old 08-18-2019, 12:07 PM
Turtleface's Avatar
I Ride: '07 ZX6R
During high school, I had an auto mechanics class, for my final two years. In rural Texas. I saw enough poorly applied RTV mess things up in those two years to swear off the stuff, unless specifically called out for, in the manual. Bad stuff, like enough RTV squished into the rocker covers of a V-8 to inhibit valve train movement, or RTV gumming up the internal works of an oil pump.
One vote for OEM!
Turtleface is offline
post #10 of 11 Old 08-18-2019, 05:44 PM
Gasket: my son had a VW 2.0 turbo and VW (German engineering) put most of the covers on with a hardening sealant. Much more difficult than RTV. Getting the covers off was very difficult. Wound up selling instead of fixing as engine was toast - my wife has told me NO MORE VWs! Finishing up replacing water pump on Honda Elite 110 - Honda uses a lot of O-rings, so much better than gaskets or RTV. Sealant can deal with bigger imperfections than gasket material and is flexible. Years ago (before most of you were born) my father taught me how to take a sheet of gasket material and a small machinist hammer and tap out a new gasket. He was trained as a B-17 mechanic during WWII.
PhotoAl is offline
post #11 of 11 Old 08-18-2019, 05:49 PM
My dad did the same with me..... Also started out as a B29 mechanic.... What a small world!
