zx6r 03 not charging, need serious help!!! - ZX6R Forum
  • 1 Post By Scorpi0
post #1 of 9 Old 07-11-2019, 03:19 AM Thread Starter
Hello, i got an zx6r 2003 last year and did a renovation on it, powdercoated the frame and stuff, but when i was done my bike wont charge, keeps drain the battery after some hours of rideing,
i replaced the battery, regulator and the stator, still the same issue, bike feels weak at idlespeed when you brake it will easily die, i checked the groundcables to the frame and that but nothing, i dont know what to do, been having this problem for 2 month soon, the battery voltage is around 13.6 - 13.8, manual says 14.2 - 15.2
jesper636 is online now
post #2 of 9 Old 07-11-2019, 11:28 AM
Battery voltage should be close to 14 when the engine is on.
Do u have any aftermarket electronics installed?
post #3 of 9 Old 07-12-2019, 10:01 AM Thread Starter
hmm not really, just converted to led in the front light,
post #4 of 9 Old 07-12-2019, 10:33 AM
What is battery voltage with engine off?
How bout with engine on, idle speed around 1600, whats the voltage?
post #5 of 9 Old 07-13-2019, 07:51 AM Thread Starter
12.7v
with engine on like 13.5, max is 13.8 when you rev it up a bit
post #6 of 9 Old 07-13-2019, 11:03 AM
Hmm. 13.8 is not too bad but not that great either.
If this happened right after u added the LED light, try disconnecting it and see if it makes a difference. U might have a bad unit thats drawing a lotta power.
post #7 of 9 Old 07-13-2019, 01:03 PM
Did you sand or file the powdercoat off where the ground cable attaches?
And did you check charging system output at idle (1600ish rpms) or did you rev it to around 4000 rpms as per the manual
leave your voltmeter on the battery and turn on the key, what does it drop to?
then when you hit the start button what does it drop to?
post #8 of 9 Old 07-13-2019, 04:05 PM Thread Starter
no did it as the whole bike was apars. but have been trying to disconnect the whole headlight cable, but still the same
post #9 of 9 Old 07-13-2019, 04:07 PM Thread Starter
yes i file the groundcable to the frame, also cleaned all the ground cables, if i rev it up to 4k its 13.8
when i start it, its dropping to 10-11v,
charging , charging system , zx6r 2003
