07 zx6r Exhaust - ZX6R Forum
post #1 of 10 Old 06-13-2019, 02:57 AM Thread Starter
07 zx6r Exhaust
Does anyone know where I can find a pipe to convert under tail exhaust to side/underbody exhaust?
AdamKonkle is offline
post #2 of 10 Old 06-13-2019, 11:20 AM
So u just want a pipe with no muffler?
Scorpi0 is online now
post #3 of 10 Old 06-13-2019, 04:06 PM Thread Starter
I do want a muffler, but I still have the stock exhaust but it's an under tail exhaust but wanting to do a side exhaust.. I'll post example
post #4 of 10 Old 06-13-2019, 04:08 PM Thread Starter
Like this
post #5 of 10 Old 06-13-2019, 04:09 PM Thread Starter
I have a muffler picked out but just trying to find a "S" pipe to make it work if anyone knows of a place to find one.
post #6 of 10 Old 06-13-2019, 05:43 PM
Were it me, I would probably obtain a used 09+ header, and bolt up from there.... as that's the model they went back to a side exit/low exhaust, the angles are probably a lot easier to match up. There are upwards of 10 years worth of aftermarket support for that header, as it hasn't changed since. Should be a good selection of options for midpipe and muffler, both new and used....
post #7 of 10 Old 06-14-2019, 09:15 PM Thread Starter
Thank you! I didnt know you could do that, will probably go that route, I appreciate it!
post #8 of 10 Old 06-15-2019, 01:23 AM
Let's make as sure as we can that I'm right enough, before you spend your money....
To the Forum: Will the '09+ header bolt up to the '07 block, and will it clear the pan?
post #9 of 10 Old 06-15-2019, 07:12 PM Thread Starter
Sounds good appreciate your input
post #10 of 10 Old 06-15-2019, 07:17 PM Thread Starter
I have been doing some research on it and a lot of people that's done say yes and the only thing I would have to do is trim the bottom fairings which isn't bad so I may order one online after more looking up
