akrapovic on zx6r 2019 - ZX6R Forum
post #1 of 27 Old 05-26-2019, 10:20 AM Thread Starter
ive posted this a week or two ago but still had no luck,anybody know how to remove baffle on a akrapovic 2019
billybow is offline
post #2 of 27 Old 05-26-2019, 10:49 AM
Have you asked Akrpovic? Judging by the size of the can, that's a relatively quiet setup. Do you have the OEM pre chamber still?
post #3 of 27 Old 05-26-2019, 12:06 PM Thread Starter
ive not got a clue mate im not mechanically minded just had the can fitted through kawasaki when i had the bike brand new
billybow is offline
post #4 of 27 Old 05-26-2019, 02:51 PM
Check the install manual that came with the can, or go to their website and download it.
Heres a link to a web page from sportbiketrackgear.com that has links to instruction documents, with photos.
https://www.sportbiketrackgear.com/a...ip-on-exhaust/
Also, as others have said, you need to get a link pipe...
https://www.sportbiketrackgear.com/a...nal-link-pipe/
... to replace that big (quieting) resonance chamber sandwiched between the slip-on and the header pipes. I know, I know ...not mechanically minded, but youll learn.
post #5 of 27 Old 05-26-2019, 03:08 PM
Post a photo of the end of the exhaust canister, from directly behind the bike.
post #6 of 27 Old 05-26-2019, 06:37 PM
The exhaust system on your bike is made up of three segments. Header, mid section, and muffler.
Your dealer almost certainly only installed a replacement muffler at the end of the system. If you're in the U.K., odds are good that the can they installed still has a valve in line to further limit noise.
The mid section is hidden under the bike, between the back of the transmission, and the rear suspension. It's a rugged, heavy, muffler. You can unbolt that and replace that heavy box with a simple straight through pipe section that has the correct mating points to bolt in place of it. Makes the bike a few kilos lighter, a bit louder, and could be reversed in an hour with simple hand tools if necessary.
post #7 of 27 Old 05-26-2019, 09:56 PM
Dean93's Avatar
I Ride: 2013 ZX6R ABS
Well it's pretty obvious, from the picture you posted you can clearly see that the pre chamber is still there, and if my eyes are not playing tricks I can see there's a baffle too.
First thing, get a link pipe and second, pull the damn baffle out.
If you don't know how to do that just youtube 'akrapovic baffle removal' and do the same.
Dean93 is offline
post #8 of 27 Old 05-27-2019, 11:21 AM
MizzouRah's Avatar
I Ride: 2016 ZX-6R ABS
When I used to have a Yoshimura exhaust that looked similar to yours, there was a screw hidden under a little piece of rubber near the top that once you removed it, the baffle would come out.
MizzouRah is offline
post #9 of 27 Old 05-27-2019, 12:09 PM Thread Starter
there is no screw for the baffle i cant find it anywhere?
billybow is offline
post #10 of 27 Old 05-27-2019, 12:18 PM
There's either a bolt on the side towards the bike holding it in or you just pull it out. Otherwise it could be welded on depending on your local emissions requirements.
Bolt
Weld
JL99
post #11 of 27 Old 05-27-2019, 01:22 PM
I really like that in the video above they state that there may be a spot weld that needs to be drilled out to be able to remove the db killer. I think this may be what the OPs problem/dilemma is.
post #12 of 27 Old 05-27-2019, 02:30 PM Thread Starter
Bolt
Weld
https://www.youtube.com/watch?v=au2TWG4FQ0w
i can see something that looks like a spot weld on the side of the exhaust
billybow is offline
post #13 of 27 Old 05-27-2019, 03:43 PM
It would be on the side of the exhaust next to the rear tire...not the side with the brand logo. All I see in your photo are the rivets that hold the stainless steel bands, which hold the carbon fiber canister together.
jd41 likes this.
post #14 of 27 Old 05-28-2019, 11:04 AM
some Akrapovic Exhaust have screws for the baffle inside... check the baffle itself if it has screws on it...
kitt0y is offline
post #15 of 27 Old 05-29-2019, 08:01 PM
Jonathanhlmn's Avatar
I Ride: 2007 ZX-6R
All you need is a hex key set, some pliers and a nice grip. The picture he is showing is the only thing you need to worry about. That one screw - take it out and grip the insert to pull the baffle out.
2007 ZX-6R
Jonathanhlmn is offline
2019 ZX6R potential problems after forcing upshift without clutch?.. Chris Lim Mechanical and Technical 11 06-25-2019 10:03 AM
akrapovic on zx6r 2019 billybow The ZX6R 15 06-02-2019 12:53 AM
2019 ZX6R from Germany chris#55 New Member Introductions 10 05-19-2019 04:57 AM
2019 Kawasaki zx6r installed brother exhaust, after entering the gear position, pinch kaixin912 Mechanical and Technical 0 02-16-2019 01:37 AM
2019 ZX6r on the way? MrZ The ZX6R 18 08-15-2018 02:36 PM
