akrapovic on zx6r 2019 - Page 2 - ZX6R Forum
post #16 of 27 Old 05-30-2019, 04:48 PM
bigmtnskier's Avatar
I Ride: 2016 Kawasaki ZX6R 636 KRT Edition, 2018 Kawasaki Ninja 400
Originally Posted by billybow View Post
ive posted this a week or two ago but still had no luck,anybody know how to remove baffle on a akrapovic 2019
There should be a torx bolt on the wheel side of the your exhaust towards the end of the carbon area.
2016 ZX6R 636 KRT
Akrapovic exhaust system
Ohlins Suspension
Lightech rearsets
PSR adjustable GP levers
Apex Clip Ons with risers
Puig Windscreen
Woodcraft spools and axle slider
Galfer steel brake lines
bigmtnskier is offline
post #17 of 27 Old 05-30-2019, 06:54 PM
Superem's Avatar
the silencer inside the slip can be removed with a small wrench. it will make the slip sound better. its not that difficult
as other have said until you remove the prechamber and install a link pipe the akra will never be loud.
akras in general are not loud. go with 2 bros or m4's if you want volume
Superem is offline
post #18 of 27 Old 06-02-2019, 02:11 PM Thread Starter
i cant find it anywhere
billybow is offline
post #19 of 27 Old 06-02-2019, 09:54 PM
Dean93's Avatar
I Ride: 2013 ZX6R ABS
Take a few pics of your exhaust from different angles and let us see what you see, maybe we'll be able to help more.
Dean93 is offline
post #20 of 27 Old 06-16-2019, 02:26 PM
I Ride: 2019 Ninja ZX6-R
I'm in the same boat as the OP. Just picked up a new 2019 ZX6R this weekend. Before I bought the bike I knew I wanted to get the carbon fiber akrapovic slip on. The dealer had a package for the ZX6R which included the akrapovic slip on and frame sliders. So thought I would just get the package. Once home I looked and noticed it had the baffle. At first I thought cool it came with the baffle. So I went to take the baffle out and noticed no hole to remove the screw holding it in there. So now I'm going to drill a hole in the side of the can where the screw is so I can take it out when I want to. Pretty messed up that they build it this way. I took picture but don't have a place to host them. So good news OP you just have to drill a hole where the screw is.
Macshan is offline
post #21 of 27 Old 06-16-2019, 06:19 PM
Cam0101's Avatar
Appears that the exhaust equipped is the ECE/EPA/EC approved exhaust. Normally this means that the baffle is welded in and can not be removed without cutting said weld. You can also see it still utilizes the butterfly valve as well.
2016 - Kawasaki - ZX-6R 636 (ABS)
Rear Wheel 130HP / ~97kw & 53ft-Ib / ~71nm
Mods: Two Brothers S1R Slip-on Exhaust, Decored OEM headers, LED lighting conversion (Headlights, Markers, Indicators), TST Industries Taillight light and TST Industries Fender Eliminator
Woolich Racing ECU Tune w/ Race Tools: Quickshifter, Launch Control & Pit Limiter
Planned Mods: Braided Brake Lines
2016 - Kawasaki - Z125 Pro
Mods: Yoshimura RS-2 Exhaust, Airbox delete with Short Ram Intake with Pod filter and LED Headlight and Markers Conversion
Cam0101 is offline
post #22 of 27 Old 07-07-2019, 12:32 PM Thread Starter
the problem i got is finding the screw
billybow is offline
post #23 of 27 Old 07-08-2019, 05:56 PM
I Ride: ZX-6R 2019 ABS
There is no screw in 2019 street legal Akrapovic slip-ons for Europe due to EURO4 restrictions. It is not removable, Cam0101 already wrote that.
CyberGasty is offline
post #24 of 27 Old 07-09-2019, 05:19 PM
Its on the tire side but the problem is the carbon fiber can doesn't have the hole to accesses it. You can see the screw. It does have a little tac weld on it but should be easy to break free. The only 2 ways I see of getting to it is a hole saw or drilling out the rivets . I will be using a hole saw this weekend on mine.
Macshan is offline
post #25 of 27 Old 08-06-2019, 02:26 PM Thread Starter
did you do yours?
billybow is offline
post #26 of 27 Old 08-09-2019, 06:06 PM
Yes and it its sounds great. Took all of about 15 minutes to do. It will you give you the sound your looking for. I used a 3/4 inch hole saw. Made a hole in line with the screw. Used an 8mm socket to brake the screw loose. It was very easy to break the weld. Just have to be careful not to drop the screw in the can. Then used pliers to grab the baffle. Gave it a little shake and it pulled right out.
Macshan is offline
post #27 of 27 Old 08-12-2019, 01:57 AM
houltmac's Avatar
I Ride: '16 ZX-6R 30th Anniversary
Here is a crappy old video I made in 2010 about mine. My 2016 was the same so no reason to think it's changed.
Matt
2016 ZX-6R 30th Anniversary
Akrapovic slip-on & link pipe, Lextech Levers, Radiator Grille, Bobbins, Micro LED Indicators, Tail Tidy, Pro Grip 717's, ProGrip Tank, K&N Air Filter
2010 Kawasaki ZX-6R 599 White (Gone)
2010 Kawasaki ZX-6R 599 Black (Gone)
houltmac is offline
2019 ZX6R potential problems after forcing upshift without clutch?.. Chris Lim Mechanical and Technical 11 06-25-2019 10:03 AM
akrapovic on zx6r 2019 billybow The ZX6R 15 06-02-2019 12:53 AM
2019 ZX6R from Germany chris#55 New Member Introductions 10 05-19-2019 04:57 AM
2019 Kawasaki zx6r installed brother exhaust, after entering the gear position, pinch kaixin912 Mechanical and Technical 0 02-16-2019 01:37 AM
2019 ZX6r on the way? MrZ The ZX6R 18 08-15-2018 02:36 PM
