akrapovic on zx6r 2019 - ZX6R Forum
post #1 of 16 Old 05-19-2019, 01:07 PM Thread Starter
Hi guys/girls ive just had a new zx6r 2019 and had a akrapovic exhaust fitted at the dealership but am a bit dissapointed with the sound is there anything i can do to make it louder?
billybow is offline
post #2 of 16 Old 05-19-2019, 01:19 PM
MotoCT's Avatar
I Ride: 2009 ZX6R
It probably has the baffle installed. It's just one screw to remove and carefully slide it out. It has to be pulled out as straight as possible or it tends to bind.
Sent from my LM-X410.FGN using Tapatalk
2019 Sponsors: Renthal, Motul, Woodcraft Technologies, Evlution Nutrition, Armour Bodies, MotoSport.com, Hookit
MotoCT is offline
post #3 of 16 Old 05-19-2019, 01:39 PM Thread Starter
i'm lost lol not mechanical minded
billybow is offline
post #4 of 16 Old 05-19-2019, 01:44 PM
Sandman's Avatar
If it's ONLY a slip-on then it's not going to be that much louder.
Sandman is offline
post #5 of 16 Old 05-19-2019, 01:51 PM
Dean93's Avatar
I Ride: 2013 ZX6R ABS
Look at the tip of the exhaust, there should be a small screw, undo that and that inner baffle should come out if you pull it straight out, that'll make it louder.
Dean93 is offline
post #6 of 16 Old 05-19-2019, 01:57 PM Thread Starter
i think its spot welded over
billybow is offline
post #7 of 16 Old 05-19-2019, 02:06 PM
Dean93's Avatar
Take a picture of the exhaust so we can see what your'e working with.
Dean93 is offline
post #8 of 16 Old 05-19-2019, 03:05 PM Thread Starter
not sure if this works or good enough
billybow is offline
post #9 of 16 Old 05-19-2019, 03:06 PM Thread Starter
billybow is offline
post #10 of 16 Old 05-19-2019, 04:06 PM
Dean93's Avatar
Looks like the baffle has been removed already, you probably still have the pre chamber box on there.
Dean93 is offline
post #11 of 16 Old 05-19-2019, 04:20 PM Thread Starter
ive not got a clue what your on about lol all i know is my last zx6r was much better sounding than this?
billybow is offline
post #12 of 16 Old 05-19-2019, 05:23 PM
Dean93's Avatar
The pre chamber box is that big ugly thing between the headers and the pipe, it's probably what makes your exhaust quieter.
If your bike came with the akrapovic installed, you can get a mid pipe like this one on mine.
Post a pic of your bike so we can see it.
Dean93 is offline
post #13 of 16 Old 05-25-2019, 02:29 PM
PinoyRider88's Avatar
I Ride: '13 ZX-6R
Well looks like a high mount exhaust too. High mounts(connected at the rear passenger peg) are generally quieter to the comparatively shorter “shorty” exhaust system because the exhaust gasses/noise have a longer passage way to travel through. Which Akrapovic did you get?
2013 ZX-6R
PinoyRider88 is offline
post #14 of 16 Old 05-25-2019, 03:39 PM
First off I didn’t know they made that color for 2019. Looks sharp! I have the all black one.
Now your exhaust probably sounds way better than stock so you should be happy about that. Yes it’s still nothing like an M4 or a Graves. Why? Well those two are low mounts and they deleted the prechamber and the exhaust valve. The only thing you can do to make it louder is disable the exhaust valve but you will need a servo buddy or your check engine light will come on. If you don’t do that then just wait. Your exhaust will brake in as you ride it and thus make it a litter louder.
A little back round on dealerships installing exhausts is that they still need to comply with local laws. The aftermarket exhaust you got was made to conform to them. You can get a race only exhaust but the cops won’t like you but it will sure as hell be a symphony to listen to.
Ride safe and you will love the bike.
Bird4 is offline
post #15 of 16 Old 05-25-2019, 06:05 PM
SaveTheShark's Avatar
Heck... Even if he got the full exhaust, I did find the Akrapovic to be relatively quiet compared to other exhaust offerings. It has a good deep tone and harmony, but not attention grabbing loud.
Bird4 likes this.
SaveTheShark is offline
2019 ZX6R potential problems after forcing upshift without clutch?.. Chris Lim Mechanical and Technical 11 06-25-2019 10:03 AM
2019 ZX6R from Germany chris#55 New Member Introductions 10 05-19-2019 04:57 AM
2019 Kawasaki zx6r installed brother exhaust, after entering the gear position, pinch kaixin912 The ZX6R 10 02-22-2019 08:52 PM
2019 Kawasaki zx6r installed brother exhaust, after the file is locked, pinch the clu kaixin912 Mechanical and Technical 0 02-16-2019 01:33 AM
2019 ZX6r on the way? MrZ The ZX6R 18 08-15-2018 02:36 PM
