fairing ZX-6R 2018 can install on New Zx6R 2019 - ZX6R Forum
 18Likes
post #1 of 20 Old 05-16-2019, 01:49 AM Thread Starter
candyman2's Avatar
I Ride: Ninja ZX-6R 2019
Feels that the face of the old year is more beautiful and pleasing So I want to know if it can be used together?
Just headlight.
Portland01 likes this.
candyman2 is offline
post #2 of 20 Old 05-16-2019, 02:01 AM
Anything is possible with enough time and money...... This one is likely going to require a lot of both.
Research how many part numbers are identical before you start buying parts.
It would be cheaper to buy an entire set of knock off '13-18 plastics and a used headlight housing, I'd guess. You could recover the cost selling your OEM plastics.
The LED headlights are the driving force behind the change in the housing.... Different cluster as well, right?
Gawernator and candyman2 like this.
Words to live by
post #3 of 20 Old 07-22-2019, 02:03 AM Thread Starter
candyman2's Avatar
After finding information And spare parts required For many months And then the result is like this. Let's celebrate
Strider and jd41 like this.
post #4 of 20 Old 07-22-2019, 04:14 AM
Congratulations..... What do you plan on doing with the parts you took off?
Words to live by
post #5 of 20 Old 07-22-2019, 08:37 AM
I Ride: 2014 Ninja 636 ABS - SOLD
That's freaking cool man. I like the older look as well. Can you detail your process for the curious?
TurbineTech is online now
post #6 of 20 Old 07-22-2019, 06:53 PM Thread Starter
candyman2's Avatar
Takes 10 hours to do, shortening to 6 minutes
Gawernator and Dhpiper like this.
post #7 of 20 Old 07-22-2019, 09:27 PM Thread Starter
candyman2's Avatar
Thumbs up
Thought that would be sold But let's see the strength of the use of My motorcycle. That it is complete and then sell
post #8 of 20 Old 07-22-2019, 11:05 PM Thread Starter
candyman2's Avatar
1. Start from studying that The various anchor points of both models are exactly the same.
2. Need to find details about spare parts that have any parts that can be used together and not If not, we must Find out which one to use and find the source to order.
3. The most difficult thing is the power system because the ZX6R 2019 headlight system is LED.
****All lighting systems, whether it is low lights, high lights and dimmer lights come together in a single bundle.
4. RAM Air and screen holder Must be changed to the year 2018, but the screen placement hole does not match Must create a new clamp.
post #9 of 20 Old 07-29-2019, 03:42 PM
Portland01's Avatar
So have you actually done this or is that CGI?
Sent from my SM-A510F using Tapatalk
candyman2 likes this.
Portland01 is offline
post #10 of 20 Old 07-29-2019, 08:12 PM Thread Starter
candyman2's Avatar
Cool
What do you think?
Otto Man likes this.
post #11 of 20 Old 09-27-2019, 07:23 PM
SaveTheShark's Avatar
So if I wanted to do the reverse of what you did (ie. make my 2013-2018 look like a 2019+)...
All I would really need to do is replace:
- The front fairing stay with ram air to 2019 version
- Replace the rear subframe to 2019
- Replace windscreen to 2019
Then all the 2019 race fairings should line up and fit?
Its a race bike, so lights etc wouldnt matter to me...
SaveTheShark is offline
post #12 of 20 Old 09-28-2019, 05:54 PM
If you were going for better looks, then you should have gone to the 2009 - 2012 fairings!
Duc995 and candyman2 like this.
post #13 of 20 Old 09-29-2019, 07:11 PM
Dhpiper's Avatar
I Ride: '16 ZX6R
https://www.youtube.com/watch?v=OM5B-v2GU1w
Awesome work and great timelapse of it! Hats off. When I saw the 2019 I cringed at how the front end changed for the worse (imo). Why make a 600cc+ sportbike look like the Ninja 400?
Cudos!
Strider and candyman2 like this.
Dhpiper is offline
post #14 of 20 Old 10-12-2019, 02:25 AM Thread Starter
candyman2's Avatar
post #15 of 20 Old 10-12-2019, 02:28 AM Thread Starter
candyman2's Avatar
***** RAM Air and BRACKET-METER You have to change to 2019 but
****************Installation locations do not match. You must fix.
*** I think there is no need to change the rear subframes, you can use the old subframes with the ZX6R 2018.
*** The windscreen 2018 is compatible with 2019.
*** Whatever Some fairing fixing positions may need to be modified.
SaveTheShark likes this.
Free Fairing set 2018 Auctmarts Auctmart fairing showoff, Please feel free to post auctmarts Pictures 8 05-27-2019 04:24 AM
2019 ZX6R from Germany chris#55 New Member Introductions 10 05-19-2019 04:57 AM
New 2018 zx6r Jdmek9 New Member Introductions 3 10-27-2018 10:14 PM
Looking for a 2000-2002 zx6r fairing Kman407 Want to Buy 0 08-31-2018 07:09 PM
2019 ZX6r on the way? MrZ The ZX6R 18 08-15-2018 02:36 PM
