zx6r 2009 Cooling fan not workin - ZX6R Forum
post #1 of 4 Old 05-13-2019, 11:23 AM Thread Starter
Question zx6r 2009 Cooling fan not workin
Hi, Zx6R when temperature go up until 110C cooling fan don't turn on, so i hook up the fan directly to the battery he works. So why don't turn on when temperature goes up 100 C ?
Donatas is offline
post #2 of 4 Old 05-13-2019, 06:15 PM
The shop manual for your bike should say what coolant temperature should start the fan.
There is a relay to switch it on.
Some part of that chain is broken.
The temperature sensor sends a signal to the ECU. Since you get a temp reading, we can presume that part works.
The ECU should have a command signal that should energize the coil of the relay, to close the power lead to the fan motor.
The fan motor will not run, unless the other side of the motor completes the circuit. It must make a connection with the other pole of the battery.
The relay may be bad. The command signal from the ECU may be blocked. The ground connection may be corroded.
Clean off any corrosion on all of the electrical connections. Rust has resistance. That stops current from flowing. Make sure the ground connection is just as clean.
post #3 of 4 Old 05-15-2019, 01:17 AM Thread Starter
[QUOTE=RJ2112;1822048]
Where I can find that relay on bike? how it looks?
Donatas is offline
post #4 of 4 Old 05-15-2019, 01:33 AM
It's near the ECU. It should be shown on a parts diagram 27002A
You will need to compare the wiring diagram to identify which pins are involved.
fan
2006 zx6r odd issue with cooling temp slawson12 Mechanical and Technical 12 04-02-2019 08:15 AM
2009 zx6r won’t start Jsepulveda19 The ZX6R 21 10-11-2018 05:45 PM
Finally tuned my 2009 zx6r rogal88 The ZX6R 8 07-30-2018 07:39 PM
2009 ZX6R to 636 Swap ZeeEx6Are New Member Introductions 0 06-16-2018 08:44 PM
07 zx6r fan/ cooling problem!! joelh82 Mechanical and Technical 15 04-29-2011 07:16 AM
