Timing help please.. - ZX6R Forum
 4Likes
  • 1 Post By spykeeboi
  • 2 Post By tsunx4
post #1 of 3 Old 03-28-2019, 04:27 AM Thread Starter
spykeeboi's Avatar
I Ride: zx6r j1
Good Morning or evening depends on the part of the world you are.
guys i have taken on the valve clearence job myself which all the valves were out, so ive stripped it in the correct order and put all the shims and buckets back in....no problem so far...then i noticed the possible problem.... whilst i thought i had it tdc1 i placed the cams down as ive removed them and the holes on the bottom of each cam where sitting at the top of the cams ie upside down if you get me...so looking at the picture i took piston 1 the lobes are all facing outwards piston 4 the lobes are facing inwards piston 2 lobes are pointing down( engaged) piston 3 inlet lobe is pointing up and exhaust is pointing down....other than ripping me a new 1 what advice would you give....shall i reinstall the cams like this or shall i reset the timing and what are the correct steps to do so...thanks in advance.
Gaz
spykeeboi is offline
post #2 of 3 Old 03-28-2019, 01:23 PM Thread Starter
spykeeboi's Avatar
I Ride: zx6r j1
quick update... I decided to reset the timing....and it turns over smoothly and no knocking....cheers guys
post #3 of 3 Old 03-29-2019, 12:50 AM
tsunx4's Avatar
I Ride: 2014 ZX-6R & 2000 Suzuki GSF600S K2 Bandit
Glad we could help.
RJ2112 and spykeeboi like this.
tsunx4 is offline
Help! 1999 zx6r timing problem? muzzy Mechanical and Technical 0 06-26-2013 07:07 AM
Timing Chain cost to repair? jcrouc03 The ZX6R 38 12-21-2012 01:26 PM
Timing Issue vs. Major Work? Booma Mechanical and Technical 11 08-03-2012 10:01 AM
need help with timing chain Bensbaby Mechanical and Technical 51 11-30-2011 10:09 AM
Advanced Timing Anyone? endeavor Mechanical and Technical 8 09-30-2011 03:03 PM
