07 rear shock - ZX6R Forum
post #1 of 5 Old 03-23-2019, 09:51 PM Thread Starter
DuurtyDon's Avatar
I Ride: 2007 zx6r and 2018 z125
07 rear shock
I was wondering if the newer model shocks or possibly zx10 shock would fit on my 07? thanks.
DuurtyDon is offline
post #2 of 5 Old 03-24-2019, 01:46 AM
Fit isn't the issue.... Springs, and valving, are.
What are your plans for the bike?
How much do you weigh in your typical riding gear?
post #3 of 5 Old 03-24-2019, 04:00 PM Thread Starter
DuurtyDon's Avatar
it will be a track day bike with occasional sunday rides. With my suit on and all that I weigh around 170-172, no gear I'm 158
post #4 of 5 Old 03-24-2019, 05:27 PM
A random eBay shock is not likely to outperform your OEM shock. If it does that's blind luck.
Even a name brand fully adjustable aftermarket unit will perform better with a service, the right spring, and correct set up.
The most right answer will be having the suspension at both ends set up for how you will use the bike.
Whether that's with your shock or another, is up to you.
post #5 of 5 Old 03-24-2019, 07:12 PM
Gawernator's Avatar
Just get the name brand aftermarket shock designed for your bike.
http://www.gawerracing.com
Gawernator is offline
FS: 09-12 Racetech G2-R Forks & Elka Stage 4 Rear Shock Dougie Fresh Classifieds 4 03-07-2019 07:19 PM
Rear shock help Brandon35 The ZX6R 7 02-05-2019 07:33 AM
ZX6r B1h and P8F Rear shock compatability ninja44 Mechanical and Technical 2 09-25-2018 10:13 AM
07 REAR SHOCK ADJ,high speed? which way? geordieninja The ZX6R 2 06-14-2009 01:05 AM
Rear Shock B1H stevewyatt69 The ZX6R 3 01-24-2009 09:38 AM
