Anyone know how to clear engine codes on 2019 zx6r? - ZX6R Forum
  • 1 Post By RJ2112
  • 1 Post By jd41
  • 1 Post By Backmarker
post #1 of 7 Old 03-15-2019, 11:28 PM Thread Starter
I heard it was pretty easy with the new dash, like how to check the engine codes or clear the check engine light. Anything will help. I installed an alarm on mine and now I got the check engine light. I tried disconnecting the battery for 30 min but that didn’t work.
Dreamland37 is offline
post #2 of 7 Old 03-16-2019, 02:17 AM
Check to see if anyone has made the '19 shop manual available on this site....
If not, grab the one that covers the preceding generation (13-18), and see if the buttonology is the same to read codes.
Odds are very good, your bike doesn't like your alarm installation.... Whether that is due to where and how you installed, or if the alarm is actually compatible with your bike, would be the question.
Can you remove the alarm and clear the check engine light?
post #3 of 7 Old 06-22-2019, 08:00 AM
I Ride: 2019 ZX6R
How to show your codes on the dash
My check engine light and tech options are all flashing after installing my pcv. I was actually trying to just set my clock when I did this but holding down the top and bottom buttons on the dash showed my codes where your mileage is.
My codes were 11, 13 in case you wanted to know.
Anyway, as for clearing them, I have no idea. Let me know if you figure out that part!
Chris Lim is offline
post #4 of 7 Old 07-21-2019, 12:35 PM
Jamoncito37's Avatar
I have the same 13 code after removing the servo or of the exhaust.
Jamoncito37 is offline
post #5 of 7 Old 07-21-2019, 01:40 PM
MrZ
MrZ's Avatar
I Ride: my sexy Julia
If you don't resolve the issue for the code to pop up...it won't go away you know...
If you have a code for faulty or missing exhaust servo, you have to plug-in a working exhaust servo or a servo eliminator.
Otherwise you will get the same FI warning and red light all the time.
MrZ is offline
post #6 of 7 Old 07-21-2019, 01:43 PM
@Backmarker was able to wire an OBDII port to clear codes on the 19's. I'll have to search and see where it was posted.
FT ECU and Woolich make an OBDII adapter.
You must use an OBDII reader to clear the codes.
Backmarker likes this.
JL99
post #7 of 7 Old 07-21-2019, 02:31 PM
Backmarker's Avatar
I Ride: 11ZX6R race, ‘19 ZX6R race, Zuma street
FYI... Do not turn your key on with any of the wires unplugged. !!!
You will get a code right away. And it won't go out on it's own anytime soon.
Code 11 is the Main Throttle Sensor.
Code 13 is the Intake Air Temp. Sensor
Buy these.....
https://www.zx6r.com/mechanical-tech...ml#post1826690
jd41 likes this.
2018 WERA Senior Superbike Middle Weight Expert National Champion
Backmarker is offline
2019 Kawasaki zx6r installed brother exhaust, after entering the gear position, pinch kaixin912 Mechanical and Technical 0 02-16-2019 01:37 AM
2018 ZX6R making ticking noise coming from engine Tyler Minton The ZX6R 5 09-29-2018 11:33 AM
2019 ZX6r on the way? MrZ The ZX6R 18 08-15-2018 02:36 PM
How To Pull FI Codes EvilTwin Guides 30 06-11-2012 10:08 AM
95 zx6r engine spoony Want to Buy 1 01-24-2009 07:18 PM
