Broke a piece - ZX6R Forum
  • 1 Post By Duc995
post #1 of 7 Old 03-12-2019, 09:40 PM Thread Starter
Broke a piece
Hey guys I changed my oil today with motul 300v man what a difference bike is super smooth now. But when I was removing the old oil filter with the special oil tool I cracked that little tray right underneath the oil filter on my 2018 zx6r is it okay if I just remove that tray completely? Or should I buy one? Thank you
A1_Digest is offline
post #2 of 7 Old 03-12-2019, 11:54 PM
I'd probably replace it as its messy enough to change the oil as it is
gruntymotor is offline
post #3 of 7 Old 03-13-2019, 08:35 AM
Id replace the piece or repair it. Before K&N fired their QC staff I used their oil filters just to have the nut. Otherwise I get out the preferred tool for filter removal - a giant pair of slip lock pliers. When changing the oil I use a piece of aluminum duct tape stud on it so that any oil that leaks will drain into the pan and not all over the bike.
PhotoAl is offline
post #4 of 7 Old 03-13-2019, 10:07 AM
Just a cap-type oil filter tool works perfect for me on the oem filters; easy on easy off with no crushing or damage to the near-by drain lip.
riverszzr likes this.
post #5 of 7 Old 03-13-2019, 10:58 AM Thread Starter
can you send me to the exact one you have please?
post #6 of 7 Old 03-13-2019, 03:22 PM
It’s stamped “65/14”, which means 65 mm and 14 flutes/sides. Just Google “oil filter cap wrench 65 mm 14 flutes” ....think I just got it at an auto store.
I normally use it with a torque wrench to torque the new filter - per the manual - to 17 N-m. Then I use a safety-wired hose clamp to make sure it doesn’t back out during my track days.
post #7 of 7 Old 03-15-2019, 01:54 PM
LiamGTR's Avatar
I Ride: '06 636
Are literally any parts on your bike not broken?
LiamGTR is offline
One piece or two piece leathers? UltraNEO Motorcycle Talk 58 11-21-2012 10:49 AM
do you wear a 1 piece/ 2 piece/ or just jeans and jacket when you ride around town? hoodsta Motorcycle Talk 64 08-17-2011 12:01 PM
New to biking - what leathers 1 piece or 2 piece thegreensnot United Kingdom 35 06-13-2011 02:15 PM
One piece comfort? zx6rSteven Motorcycle Talk 11 06-07-2011 03:07 PM
