Zx6r 05- no electric to fuel pump or injector - Page 3 - ZX6R Forum
post #31 of 45 Old 03-10-2019, 09:10 AM Thread Starter
TheSkimbz's Avatar
I tryed to contact him, not answering.. Maybe he calls back..
TheSkimbz is offline
post #32 of 45 Old 03-10-2019, 09:13 AM Thread Starter
TheSkimbz's Avatar
If someone knows can it bypass im interested to hear..
post #33 of 45 Old 03-10-2019, 09:23 AM
Random question: Since youre from Finland.....Do u ever watch the Beyond the Press channel?
Scorpi0 is online now
post #34 of 45 Old 03-10-2019, 09:33 AM
I Ride: ZX6R 2006
The ecu key and ignition is a matched set. If it does work when you switch all of them over you have a problem with unmatched key/ecu. The immobilizer is only an antenna and does not need to be matched.
Regarding bypassing, i have not found any way to do that, so a new set is needed. The red key is a master key, needed for recoding new keys and recoding a new ecu (which have to be completely new and cost about 1000 euros).
Regarding the FI light, you can put the bike in a dealer diagnosing mode (search here on the forum on how) and read out a code for what is wrong.
Also pick up the service manual here if you havenít already.
hehy is offline
post #35 of 45 Old 03-10-2019, 10:35 AM Thread Starter
TheSkimbz's Avatar
No 🙄🤣
post #36 of 45 Old 03-10-2019, 10:53 AM
I Ride: ZX6R 2006
You can however buy a used set (ignition, ecu, keys, tank lock and Seat lock). If you can find a set that is.
hehy is offline
post #37 of 45 Old 03-10-2019, 10:59 AM Thread Starter
TheSkimbz's Avatar
How can i be sure that its immobilizer? Im building stunt bike.. So if i dont need ignition switch its enought to buy us ecu box?
post #38 of 45 Old 03-10-2019, 11:00 AM Thread Starter
TheSkimbz's Avatar
Its didnt worked with my primary bike ignition switch and master key + antenna.. Fi light keeo flashing all the time when power is on
post #39 of 45 Old 03-10-2019, 12:34 PM Thread Starter
TheSkimbz's Avatar
It works now!!! It was immobilizer.. Can anyone show me link for ecu box without immobilizer? Is there different part number for ecu box with immobilizer and without immobilizer
post #40 of 45 Old 03-10-2019, 01:19 PM
I Ride: ZX6R 2006
There is a different part number for the EU and US ECU.
US version: 21175-0057
EU version (with imobilizer): 21175-0046
This would have to be bought alongside a new US ecu and harness i think
https://www.hsbkracing.com/parts-and...ness-assembly/
hehy is offline
post #41 of 45 Old 03-11-2019, 06:30 AM
MrZ
MrZ's Avatar
I Ride: my sexy Julia
Because "how to bypass the immobiliser = how to steal a bike"
Correct, US ecu works with US harness.
MrZ is offline
post #42 of 45 Old 03-26-2019, 11:51 AM
I Ride: 03 ZX-6R 636 , 06 DRZ400 Motard
It could easily be a dead relay. On my bike there are several relays, headlight, starter and one is for the fuel pump.
burke is offline
post #43 of 45 Old 03-26-2019, 11:52 AM
oops nevermind, just saw issue has been resolved.
burke is offline
post #44 of 45 Old 04-06-2019, 02:43 PM
I have the same issue ive been dealing with. Ehat i noticed though is if i remove the fuse on the starter relay under the left side of seat and plug it back in it will start. But once i turn it off i would have to redo the process again to get it to start. Still scratching my head on this. Let me know it works.
Dtruong is offline
post #45 of 45 Old 04-06-2019, 02:44 PM
Same lol
Dtruong is offline
ZX6R 09-12 Fuel Pump Malfunction? azlan_87 Mechanical and Technical 20 02-27-2019 05:17 AM
ZX6R Fuel Pump Wiring overheating [email protected] Mechanical and Technical 2 02-14-2019 02:37 AM
ZX6R 2010 wont start fi light on no fuel pump sound kawaz550gp Mechanical and Technical 2 11-15-2018 02:11 PM
Need fuel pump for an 08 zx6r asap Jamkawi1 Mechanical and Technical 0 08-24-2018 07:29 AM
2006 ZX6R Fuel Pump question jniedzi1 The ZX6R 1 05-19-2009 09:23 PM
