2005 zx6r - ZX6R Forum
post #1 of 13 Old 03-08-2019, 09:00 PM Thread Starter
2005 zx6r
I had issues with the old wiring harness, I took it out got a new one got it put in, now the bike is iffy in wether it starts or not. If it does start it’s for a few seconds and then shuts off. The last few times I’ve tried it doesn’t even try to start. I’ve checked all wires and made sure throttle body was tight and airbox and all vent hoes. Ran before I swapped the harness. Somebody helpppp
Racehead12 is offline
post #2 of 13 Old 03-08-2019, 09:18 PM
Have u tried giving it a bit of throttle?
Does it just keep cranking or what?
post #3 of 13 Old 03-08-2019, 09:26 PM Thread Starter
I have tried throttle, I’ve tried no throttle, I’ve tried the idol adjuster, I tightened everything down like throttle body checked all plugs and now it doesn’t attempt to fire just cranks
post #4 of 13 Old 03-08-2019, 09:27 PM Thread Starter
Before I tightened everything it would fire with very little throttle and then die
post #5 of 13 Old 03-08-2019, 09:40 PM
Do u have all your air sensors hooked up correctly?
post #6 of 13 Old 03-08-2019, 09:51 PM Thread Starter
Yes, everything is hooked up the way it came apart.
post #7 of 13 Old 03-08-2019, 09:57 PM
Do u have any starter fluid? Spray it into the intake as its cranking. See if it starts like that.
post #8 of 13 Old 03-08-2019, 10:01 PM Thread Starter
I’ll try it tomorrow, it’s fired multiple times before I tightened everything up but wouldn’t stay running
post #9 of 13 Old 03-08-2019, 10:07 PM
Well its either not getting fuel or not getting spark. Im assuming u already know how to test for spark.
For fuel, if u already have the airbox off, u can actually look down into the throttle bodies with a flashlight to see if its spraying fuel.
post #10 of 13 Old 03-08-2019, 10:12 PM Thread Starter
Yeah I tried spark, I’ll check fuel in the morning, don’t wanna wake everyone in the house up
post #11 of 13 Old 03-10-2019, 03:41 AM
Originally Posted by Racehead12 View Post
I had issues with the old wiring harness, I took it out got a new one got it put in, now the bike is iffy in wether it starts or not. If it does start itís for a few seconds and then shuts off. The last few times Iíve tried it doesnít even try to start. Iíve checked all wires and made sure throttle body was tight and airbox and all vent hoes. Ran before I swapped the harness. Somebody helpppp
How sure are you about that new harness?
post #12 of 13 Old 03-10-2019, 02:14 PM Thread Starter
It was melted at one spot. It’s back to trying to fire now with a new fuel pump, but the fuel pump is constantly making noise
post #13 of 13 Old 03-10-2019, 02:31 PM Thread Starter
The old harness was melted**
2005 zx6r stunt bike build aboogie808 Stunting 10 03-20-2019 05:52 PM
New Member Poughkeepsie, New York 2005 Zx6R Justin22 New Member Introductions 12 01-16-2019 08:51 PM
Problem Starting 2005 ZX6R mitchgus21 The ZX6R 3 01-08-2019 03:11 AM
2005 ZX6R - North Georgia Freggles Classifieds 0 07-07-2018 10:10 AM
