ZX6R 2013+ Steering Damper - ZX6R Forum
This is a discussion on ZX6R 2013+ Steering Damper within the The ZX6R forums, part of the ZX6R Forum category; Hey All, First of all let me say that since I bought the zx6r 2015 half an year ago I was lurking here, but after ...
Like Tree13Likes
Reply LinkBack Thread Tools
Unread 03-08-2019, 02:56 AM   #1
Lightbulb ZX6R 2013+ Steering Damper
Hey All,
First of all let me say that since I bought the zx6r 2015 half an year ago I was lurking here, but after I encountered an issue I had to join the boat and start a thread which going to help to everyone who is in need of steering damper for the zx6r 2013+ model.
So my story is that I bought a steering damper from Bitubo which I was certainly sure it will come with the mounting brackets, but sadly it didn't so now I'm stuck with a damper with no way to mount it.
So lurking in this forum i found this thread: https://www.zx6r.com/zx6r/39397-2013...-question.html
It was very informative but both those parts:
11056-2308 - Triple bracket
11056-2315 - In front of tank bracket
Cost a total of 150$ (that is without my country taxes which will make it 250$).
I started looking for a bracket that will fit or make a bracket, so I got some Chinese "Matris" zx6r mounting bracket but the diameter of the clamp is big (25mm while the Bitubo is 22.8mm) and I have to use something to fill the gap between the damper and the clamp (big room for errors).
Instead I kept looking and found this part:
11054-1903 - Triple bracket of a zx10r 2010, cost me 10$ on eBay, now all I had to do to fit the part to the triple, this required modification and basically just make on of the holes bigger (used a drill and just drilled a bit and checked a couple of times until the hole was perfect size), when you install it you'll see that there is a part touching the clip-on secure bolt, so i just used a small spacer and now the part is sitting great with good clearance to the gas tank.
Now I have to find a gas tank bracket, I ordered a zx6r 2009 bracket because i understood that it can be used on the 2013+ model (Part: 11055-1147 cost around 18$) but it's on a back order, So I'm thinking of getting the original one that fits 11056-2315 which is like 37$ (Double the money) and there is the zx10r mount (Part 11054-0023 / 11054-0023-18R) but not sure if it will fit on the zx6r.
Meanwhile hopefully the part will arrive soon so I can update with pictures.
Thanks for reading and hope it helps anyone.
*The steering stem bolt and weird gold bracket in the pictures is from the Chinese bracket.
ZX6R 2013+ Steering Damper-54377139_387921955354531_8774803109839896576_n.jpg
ZX6R 2013+ Steering Damper-53630617_10156885639838886_1412981890343763968_n.jpg
ZX6R 2013+ Steering Damper-53482185_10156885639968886_8945117100205146112_o.jpg
ZX6R 2013+ Steering Damper-52552004_10156885640333886_5799858132108705792_o.jpg
ZX6R 2013+ Steering Damper-54041376_428685364576508_2558763175029768192_n.jpg
Fiftythree53 is offline
Unread 03-11-2019, 11:03 AM   #2
** Update
So partzilla just told me that it's on back order and it nation wide or something like that which means there is no ETA on that.
If someone is selling this part: 11055-1147 please let me know, right now project is delayed until i can get my hand on this bracket.
Unread 03-11-2019, 12:44 PM   #3
I bought a Chinese type damper just for the fitting kit for the reasons you describe. My plan is to replace the damper tube with a well known one once i get to give it a try.
Not sure if this is any help to you.
gruntymotor is offline
Unread 03-11-2019, 02:25 PM   #4
Bike looks nice!
Mind checking the damper diameter for me? It'll be very helpful.
Thanks
Unread 03-11-2019, 10:40 PM   #5
Gawernator's Avatar
Id throw all that stuff away or sell and just get the Ohlins kit from Mike Canfield
PhotoAl likes this.
Gawernator is online now
Unread 03-11-2019, 11:53 PM   #6
what does the ohlins mounting kit do that the above doesnt?
Unread 03-12-2019, 02:34 AM   #7
Ohlins mounting kit doesn't fit the Bitubo damper, i tried it.
The Matris / Hyperpro can fit but the diameter has differences.
On another note to help everyone who wants a bit of overview options for steering damper:
OEM ZX6R steering damper kit (the Kawasaki version Ohlins SD021) is a BS damper and needs to be revalved (even if you buy the kit from factory).
The Ohlins SD042 is the steering damper you want if you into Ohlins, only thing is that this damper cost a fortune.
Both kits comes with mounting parts (SD021 comes only if you buy it from Kawasaki dealer since the mounting parts are not made by Ohlins but made from kawaski, parts are: 11056-2315 and 11056-2308)
Now for alternative you have:
GPR V4 - great damper but heard it has to be maintained quite a lot due to leaking from now and then, comes with mounting kit.
TOBY - didn't really get a review and feeling of it but heard it's nice, comes with mounting kit.
Hyperpro - heard good things on them, comes with mounting kit.
Bitubo - I got this one, heard good things on them tried it and got one, but it doesn't come with mounting kit so you have to buy / fabricate kit (reason i made this thread)
Gubellini - well made damper but no personal experience. (Don't know if it comes with kit or not)
There are more out there... just make sure you get a mounting bracket with it else you'll have to get those 2 overpriced parts (11056-2315 and 11056-2308)
Unread 03-12-2019, 03:36 AM   #8
Gawernator's Avatar
Its around $600 not cheap but not a fortune IMO
Unread 03-12-2019, 03:46 AM   #9
Compared to others it is...
Unread 03-12-2019, 05:44 AM   #10
Ahhh, well - that scuppers my plans! I was planning on getting a hyperpro as the one on my zx10r worked perfectly well and wasnt insanely expensive.
I'll report back if this chinese one lasts more than 1lap
Unread 03-12-2019, 01:02 PM   #11
Bike looks nice!
Thanks
My bike is not here at the moment - will do as soon as i can, maybe the weekend
Unread 03-12-2019, 05:04 PM   #12
Gawernator's Avatar
Buy once, cry once!
sbk1198 likes this.
Unread 03-12-2019, 05:22 PM   #13
Director of Moderation
Buy once, cry once!
Yep! And if you're on a budget just buy a used one. There are lots for sale in great condition. I bought one for $225 in perfect condition that I used for like 4 years on a different bike. The one on my R3 I think I got for $200, but then I had to buy mounting brackets from Graves so that brought up the total to about $300. Still way less than $500-600.
The thing I like about Ohlins (besides that they're the best at what they do), is that there's a lot of literature out there for their products and you can learn how to service them pretty easily. And if you don't want to, there's always a shop that has the tools and knowledge to work on Ohlins. Bitubo though...Bitubo who??
sbk1198 is online now
Unread 03-13-2019, 12:24 AM   #14
You're right, Ohlins is the most known company for suspension period.
But it doesn't mean other products are lesser, more like lesser known.
I did my mistake buying this, no need to give me hard time for it.
Unread 03-13-2019, 06:36 AM   #15
Bike looks nice!
Thanks
Got my nephew to measure - 24.4mm diameter
bitubo , ohlins , steering damper
ZX6R 2013+ Who is using a Steering Damper? ZXer The ZX6R 9 10-13-2018 04:19 PM
What Steering Damper for a ZX6R 95-97 devo The ZX6R 2 08-29-2009 12:29 PM
Steering Damper for '05 zx6r NinjaLoon Want to Buy 0 06-30-2009 08:15 AM
05-06 zx6r steering damper ... rick249 Want to Buy 0 02-07-2009 09:56 PM
Powered by vBadvanced CMPS v3.2.3
