Need help! Weird electrical issues! - ZX6R Forum
 5Likes
  • 1 Post By 96zx6r
  • 1 Post By riverszzr
  • 1 Post By 96zx6r
  • 2 Post By PhotoAl
post #1 of 14 Old 03-05-2019, 03:50 PM Thread Starter
96zx6r's Avatar
I have a 96 zx6r and I am having electrical issues. The bike sat for a few years and now I am trying to get it running again. I bought a new battery and when I hit the starter, the starter relay just clicks, nothing else happens. I have tested the fuel pump hooked directly to battery and it works. If I unhook the fuel pump the starter will turn over and it will run off a fuel bottle. I have also replaced the starter relay and fuel pump relay. Trying to start the bike in neutral and with kickstand switch bypassed. Any help would be appreciated! Thank you!
96zx6r is offline
post #2 of 14 Old 03-05-2019, 04:21 PM
Take the cables off the starter, and the starter relay. Clean up the metallic contact areas, so there is no corrosion. Do the same with the negative battery cable, at both ends. The frame connection in particular.
Great everything you take apart, with dielectric grease so it doesn't corrode again.
post #3 of 14 Old 03-05-2019, 04:24 PM Thread Starter
96zx6r's Avatar
I’ll give that a try!
96zx6r is offline
post #4 of 14 Old 03-05-2019, 04:33 PM
I'm assuming you don't have a multimeter?
post #5 of 14 Old 03-05-2019, 05:41 PM Thread Starter
96zx6r's Avatar
Yes I have a multimeter.
96zx6r is offline
post #6 of 14 Old 03-05-2019, 05:41 PM Thread Starter
96zx6r's Avatar
Cleaning all termanals didn’t fix anything.
96zx6r is offline
post #7 of 14 Old 03-05-2019, 05:43 PM Thread Starter
96zx6r's Avatar
It’s weird if I unplug either the fuel pump or the fuel pump relay it will fire but not with both plugged in.
96zx6r is offline
post #8 of 14 Old 03-05-2019, 06:12 PM
So the problem is likely common to both. If the path for current to flow is not open (you just reduced the odds of that), the next most likely problem is a short circuit.
When you unplug the pump or pump relay, you open the path the short is on.
I'd expect that the pump has an issue..... The relay feeds the pump, right? With the pump disconnected, you have the problem, if the relay is still connected?
post #9 of 14 Old 03-06-2019, 10:33 AM Thread Starter
96zx6r's Avatar
If the pump is disconnected engine turns over with relay plugged in, if I disconnect the relay the engine turns over with pump plugged in, pump doesn’t make a noise
96zx6r is offline
post #10 of 14 Old 03-06-2019, 01:46 PM Thread Starter
96zx6r's Avatar
Well the new fuel pump helped but still not starting every time I hit the starter, and now it looks like I’ll have to rebuild the carbs since there is a nice puddle of Sunoco 112 on the floor.
96zx6r is offline
post #11 of 14 Old 03-07-2019, 06:04 AM
^ not weird and not surprised on either/any issues....... that is what happens when you let them sit for a few years ?!
Sounds like you have more work to do and you will eventually be able to enjoy riding it
What else is old and crusty and needs attention!!!!!!!!!!!!
post #12 of 14 Old 03-07-2019, 12:38 PM Thread Starter
96zx6r's Avatar
Ok here is the latest, it depends on what the fuel pump case comes in contact with if it will start, if it touches metal ( like frame ) it will start.I’m assuming it is a ground issue somewhere.
96zx6r is offline
post #13 of 14 Old 03-07-2019, 02:49 PM
leising's Avatar
I Ride: 2001 zx6r and 2011 zx6r
Fuel filter been changed? There could be some cloggage in the filter. I think they go for 9 buckaroos. Might be worth a shot if you are still scratching your head.
If a man does not have sauce, then he is lost. But the same man can get lost in the sauce.
leising is offline
post #14 of 14 Old 03-07-2019, 04:16 PM
Sounds like you just found the problem, the ground path for the fuel pump is not complete. If you have the wiring diagram see if you can figure out how it is supposed to be grounded and check that connection.
riverszzr and RJ2112 like this.
PhotoAl is offline
'17 Weird starting / battery issues jdubs Mechanical and Technical 7 07-09-2018 02:37 PM
Electrical help needed 05-06!! Notthebread Mechanical and Technical 6 03-04-2012 10:33 AM
02 zx6r electrical issues. zerotwozx6 Mechanical and Technical 3 09-09-2011 11:32 AM
damn bike, electrical issues now jasonstiller Mechanical and Technical 13 12-09-2010 01:09 PM
Muliple Rideability Issues [detailed!] mateospeed The ZX6R 42 02-05-2010 09:20 AM
