Front brake issue - ZX6R Forum
post #1 of 6 Old 02-19-2019, 08:02 PM Thread Starter
antcampo4's Avatar
Front brake issue
I have a 2013 and the brakes on it have been fantastic (all stock with the exception of aftermarket brake lines). I daily the bike year round and one day mid day after riding it in the morning the front brake had no friction. No resistance at all and I can't figure out what it could be. There is no leakage and if I continuously pull the lever after a hand full of times the pads finally squeeze. If I try this while riding there is no response. What could it be?
antcampo4 is offline
post #2 of 6 Old 02-19-2019, 08:06 PM
Welcome. Take time to submit a new member intro.
Does this bike have ABS?
JL99
post #3 of 6 Old 02-19-2019, 10:35 PM
Air in the lines...... When was the fluid completely replaced with fresh? From a new, sealed container?
post #4 of 6 Old 02-19-2019, 10:55 PM
Very first short term fix, is bleed the system at the MC, with the zerc fitting that is in place for this reason. Pump the brake until you have pressure, hold the pressure and slightly crack that fitting open.
Cover everything in rags first.....
post #5 of 6 Old 02-20-2019, 08:00 PM
leising's Avatar
I Ride: 2001 zx6r and 2011 zx6r
Your Brake Lever should be firm, if it is not, there's definitely a leak (or air in lines so you need to bleed first), if you dumped it, the master cylinder could be leaking, the install OR the after market lines are not tight and become loose.
My next thought is is that I'd look at your brake pistons. If they are corroded then they well not slide enough to hit the pad! I had* soft ass brakes where I'd be 95% and the brake would finally get firm! (not fun for the track). So I replaced the calipers (in this case a set of hayabusa ones as they are larger). Due to the rusty pistons. I thought about replacing just those but the hayabusa brakes were cheaper! LOL!
My 3nd and final check would be fork seals, if they leak then they get on your brake rotors and you slide, that also happened to me.
So yeah Leaks from lines (got undone), Master cylinder is whopped, and then corroded pistons.
“If a man does not have sauce, then he is lost. But the same man can get lost in the sauce.”
leising is offline
post #6 of 6 Old 02-21-2019, 11:10 AM
KawasakiBrad's Avatar
+1 on bleed the brakes
You're probably low on fluid (top that up while bleeding)
How much of your pads are left? Anything less than 2mm (1/16") requires replacement.
kawasakibrad.com
KawasakiBrad is offline
Reduced braking power but pads are in good shape. Please help. polkavin Mechanical and Technical 11 10-30-2018 02:41 PM
Zx6r brake issue Petewins The ZX6R 1 07-15-2018 08:14 AM
Rear brake Issue MuddFoot The ZX6R 2 06-29-2009 08:53 PM
