Akrapovic link pipe - ZX6R Forum
post #1 of 10 Old 02-10-2019, 04:02 AM Thread Starter
Lloyd perry's Avatar
Akrapovic link pipe
Hi all, I have a 2012 zx6r performance edition which came with the akra slip on. I've just been looking online and found the akra link pipe for £200. Is it just just a case of bolting this on I will I need a remap and or new headers ect. Cheers for the help
Lloyd perry is offline
post #2 of 10 Old 02-10-2019, 04:14 AM
The catalytic converter is built into the header, rather than the box the link pipe replaces. That means the back pressure is controlled by the header..... You can remove the box without having to remap the fi.
It would run stronger with a re map. If you go the next step and remove the cats, the remap is a very good idea.
post #3 of 10 Old 02-10-2019, 04:32 AM Thread Starter
Thanks for the reply. Is it really worth forking the 200 out for it then? I'm looking for it to be a bit louder. I'm not too bothered about performance as I'd just buy a zx10. It would be nice as a added bonus though.
post #4 of 10 Old 02-10-2019, 10:08 AM
Losing more than 10 lbs is similar to gaining a couple of hp. I would expect the exhaust to be quite a bit louder, as well. You would probably hear more of the sharper, higher pitched content.
post #5 of 10 Old 02-10-2019, 11:33 AM Thread Starter
I've also been looking at other pipes from ixil and arrow that are half the price of the akra and from what I can see steel is steel. What do you think as to going for the cheaper option. Is it worth it?
post #6 of 10 Old 02-10-2019, 12:52 PM
We have a long term member who swears by ixil. Based on his recommendation, I wouldn't hesitate.
post #7 of 10 Old 02-11-2019, 01:32 AM
Dean93's Avatar
I Ride: 2013 ZX6R ABS
You can find the Akra link pipe for $190 on solomotoparts, I've got the same one on mine, worth every penny.
Dean93 is offline
post #8 of 10 Old 02-11-2019, 03:00 AM Thread Starter
I'm located in the UK so I'm not sure how much that would cost with import duty but I bet it's a few quid.
post #9 of 10 Old 02-11-2019, 09:43 AM
The Ixil is a quality part for much less money.... I think it does not have the welded on brackets to support the covers the OEM box uses. that could be changed by a shop if you feel the need, and that would still cost less than the Akropovic.
post #10 of 10 Old 02-25-2019, 08:55 AM
houltmac's Avatar
I Ride: '16 ZX-6R 30th Anniversary
I bought my Akra link pipe for the 2016 from sportsbikeshop.co.uk for about £150 delivered. It sounds deeper, throatier and louder. Definitely worth it for me. And if you feel the weight difference itís huge. Love mine.
Matt
2016 ZX-6R 30th Anniversary
Akrapovic slip-on & link pipe, Lextech Levers, Radiator Grille, Bobbins, Micro LED Indicators, Tail Tidy, Pro Grip 717's, ProGrip Tank, K&N Air Filter
2010 Kawasaki ZX-6R 599 White (Gone)
2010 Kawasaki ZX-6R 599 Black (Gone)
houltmac is offline
07/08 Exhaust Options Quarkz The ZX6R 279 05-13-2019 02:23 AM
Akrapovich link pipe Lloyd perry Mechanical and Technical 0 02-10-2019 02:10 AM
05 Kawasaki zx-6R 636 build 05636RIDER Pictures 39 09-29-2011 01:03 PM
09 pinebox link pipe! Talk to me! bcroninuk The ZX6R 0 02-26-2011 11:09 AM
