2006 636 ninja harness cranshaft position sensor help - ZX6R Forum
 4Likes
  • 1 Post By laggy311
  • 1 Post By RJ2112
  • 1 Post By riverszzr
post #1 of 6 Old 12-23-2018, 02:14 AM Thread Starter
Bought bike found whole harness and was chewed by mice undertank black square 4 prong harness i have no body harness to connect this .....i know obviosbly where that connector goes and the green single wire near the kickstand the other two on this harness i have no idea plz help ....is this why im not getting spark the bike cranks i get fuel to but this whole harness is missing can someone please help ive attached two pics i cant find my first post so the connector on the top left of this plugs into the crankshaft plug and green wire is kickstand where do two wires on right side go Anyone plz
ridey14r is offline
post #2 of 6 Old 12-25-2018, 09:37 PM
laggy311's Avatar
I Ride: Dirty
A) punctuation is horrible dude
B) everything you need to do is under the tank and behind the right fairing piece.
The reason you are not getting spark is because the ECU is not getting a crankshaft position so itís protecting itself electronically because....
That boxy item is the crankshaft position sensor. Itís goes right next to crankshaft timing gear. Itís all behind the ignition cover on right side of bike. Itís secured with 2 bolts at 57 in-lbs NOT ft-lbs. The cover bolts are at 87 in-lbs.
The next thing inline is the grommet that goes between case and ignition cover. You will most likely need a new gasket 11060-1867.
The item to the right, I believe, is the oil pressure sensor which goes right under/behind the ignition cover plate. @RJ2112 and @riverszzr , am I right on this?
The green wire is kickstand. (Sounds like you know that)
The last plug should have a female recipient to the right of the starter. All under the tank in that mess towards the right side of the bike, rear of the airbox. (Sounds like you know that).
Youíll need just a couple dabs of rtv black as per the manual below, at the case halves in the engine side of gasket and around the sealing grommet. Make SURE youíve got an in-lbs capable torque wrench.
Yo momma so fat, Thanos had to snap twice.
Sitzpinklers
laggy311 is offline
post #3 of 6 Old 12-25-2018, 11:58 PM
The connection at the far right looks just like the connection for my oil pressure switch on my '09.
laggy311 likes this.
post #4 of 6 Old 12-26-2018, 08:34 AM
That is what that one is...........
post #5 of 6 Old 12-26-2018, 08:34 AM
he has a couple threads going on this- I added pictures to his other thread............
post #6 of 6 Old 01-07-2019, 04:51 PM
I Ride: 03 ZX-6R 636 , 06 DRZ400 Motard
Laggy311 is 100% correct.
burke is offline
2006 ninja 636 zx6r crankshaft wiring help !!! ridey14r Motorcycle Talk 4 12-23-2018 09:59 AM
