one turn signal out....why - Page 2 - ZX6R Forum
 12Likes
post #16 of 27 Old 12-19-2018, 07:53 PM Thread Starter
Kman407's Avatar
I Ride: 01 zx6r ninja
Alright update time, So i manged to get the front turn signals working after i pulled the wire out of the non working one and switched it around. after that i put the key in and Wala. she worked. i then took the turn signals off since i had to put the fairing back on. after putting the front fairing on i wired it up again. but this time the turn signals didnt work AGAIN! and now the back turn signals dont work! i also noticed that the turn signal light on the Cluster gauge dont turn when i hit the signal switch. ABOUT LOST MY PATIENCE WITH THIS $#!T.. Any idea what a shop would charge for a job like this. The bike works fine and all other lights work such as headlight, and rear light. Anyone from the forums live in or around the Central Florida area that knows how to fix this issue?
Kman407 is offline
post #17 of 27 Old 12-20-2018, 02:02 AM
Believe it or not, you are making progress.... I would be betting on one open connection, now. Either a blown fuse, or a loose ground, or a broken wire.
You got everything to work. +1
You got everything to fail.... -0.5 (you changed the problem, which means you are affecting the source, and not a symptom. Root cause. Very important, in solving problems.)
If you're getting this far, without using a multimeter you should have it figured out in no time....... If you use the right tool for the job.
Not trying to rain on your parade, this is meant to be encouragement.
Elijah likes this.
post #18 of 27 Old 12-20-2018, 04:44 AM
RJ...I think u just confused the fuck out of this dude lol.
I would concur.
RJ.... Love ya buddy but sometimes you pour about 3 gallons worth of information on people that can't handle a cup full
Why do I ride as number 69? Well, its a number that you can still read when the bike is upside down after a crash." - Nicky Hayden
PowerGroove is offline
post #19 of 27 Old 12-20-2018, 04:46 AM
I just find it impressive that RJ has the time to actually hammer out some of the replies he does! Don't you have a job?
post #20 of 27 Old 12-20-2018, 05:14 AM
Originally Posted by PowerGroove View Post
I would concur.
These things mostly get written when I wake up in the wee hours of the morning, and have nothing better to do with my time.
Technical problems require technical explanations.
PowerGroove likes this.
post #21 of 27 Old 12-20-2018, 05:18 AM
I don't work at 0400..... If I'm awake and have nothing more pressing to do, I will take on the task of describing some portion of what makes motorcycles magic.
It's a life long passion. Fascinating stuff, IMHO. If I can share some of that, and someone benefits I've paid back some of the kharma that has gotten me where I am.
post #22 of 27 Old 12-20-2018, 06:51 AM
Just givin' ya shit man
I've been up since 3am.... editing video since 4...
post #23 of 27 Old 12-20-2018, 09:09 AM
Elijah's Avatar
Location: The Democratic People's Republic of Austin, Texas
I Ride: 2011 ZX6R a.k.a. the beast. 2012 Ninja 650 a.k.a. Bambi after that unfortunate incident with a deer
Editing video is that the new euphemism for wanking?
Just kidding, bro.
RJ2112 and Kman407 like this.
2012 Ninja 650
2011 ZX6R
My YouTube Channel - A Bike and Its Boy
Elijah is offline
post #24 of 27 Old 12-20-2018, 10:41 AM Thread Starter
Kman407's Avatar
@RJ2112 , so as of 20 minutes ago i went and opened the fuse box and long behold the dang tail fuse was blown. i guess that happen when the light came untangled from my wiring job and touched the rim of the bike. swapped fuse out and all turn signals seem to be working. Now only question is are the front turn signals suppose to stay lite up the whole time? reason i ask is the front turn signals on mine only turn on when i activate the switch for the individual signal. Do you think that would be a problem with the dmv when i go get the bike inspected? or is that normal operation. Again thanks for the help and walk through.
Kman407 is offline
post #25 of 27 Old 12-20-2018, 12:18 PM
Elijah's Avatar
On my 2011 the turn signals are normally Off until you activate them with the switch then they blink. So, if "the front turn signals on mine only turn on when i activate the switch for the individual signal." is how they're working, that sounds right to me.
2012 Ninja 650
2011 ZX6R
Elijah is offline
post #26 of 27 Old 12-20-2018, 12:23 PM
Normal ops, on my '09..... off until you command the blinker to turn on. Good job on following through.
post #27 of 27 Old 12-21-2018, 07:30 AM
Just kidding, bro.
I get that out of the way at least twice before starting to edit.
Turn signal question 09-12 zx6r gnos420 Mechanical and Technical 2 08-25-2018 08:49 PM
Turn signal advice jpop8807 The ZX6R 15 08-29-2012 04:42 PM
Need help turn signal brar The ZX6R 15 03-03-2012 03:09 PM
LED Turn Signal relay RPMAddict The ZX6R 4 02-28-2009 01:04 PM
Turn signal parts for 2005 ZX6R steiger1990 The ZX6R 7 02-18-2009 05:24 PM
