Does quick action throttle always make throttle 'heavy' - ZX6R Forum
  • 1 Post By blank
post #1 of 9 Old 08-14-2018, 01:22 PM Thread Starter
Guest
Question Does quick action throttle always make throttle 'heavy'
Alright guys, just installed a quick action throttle on my 2017 and its made the throttle action really 'heavy' for want of a better word, like its more of a struggle to twist.
Do all quick action throttles do this in your guys experience on the zx6r? wondering if its been installed wrong or i've bought a duff brand...
25627 is offline
post #2 of 9 Old 08-14-2018, 01:46 PM
blank's Avatar
I Ride: 06 CBR600RR (Sold), 2010 R1 (Sold), 2014 1199R, 2014 ZX6R
I have the motion pro rev2 and it's not "heavy" but it does have a some additional resistance. Does it snap back really quick? That is by design.
Indy likes this.
blank is offline
post #3 of 9 Old 08-14-2018, 03:45 PM
Site Admin
WERA689's Avatar
I've actually never installed one on any of my bikes, but it makes sense to me that you're changing the leverage ratio of the throttle tube/cable actuation, so it should be a bit "stiffer" than stock.
Neil
WERA689 is offline
post #4 of 9 Old 08-14-2018, 04:55 PM
Same here. Would look at cable routing and return rate.
post #5 of 9 Old 08-15-2018, 02:27 AM
The bigger spool will require slightly longer throttle cables..... Did you adjust the length of both to compensate?
Words to live by
post #6 of 9 Old 08-15-2018, 11:36 AM Thread Starter
Guest
Yeah it snaps back really quick, it just requires alot more effort to pull open the throttle.
All looks good to me tbh, got it installed by a mechanic and the throttle springs back quick.
yes the kit came with supplied cables plenty of length.
I'm starting to suspect that the QA throttle i bought isn't much good. Its brand is 'active' made in japan apparently.
I'm gonna try a different brand to see if it is that...
25627 is offline
post #7 of 9 Old 08-15-2018, 11:37 AM Thread Starter
Guest
by the way thanks for the replies guys
25627 is offline
post #8 of 9 Old 08-15-2018, 03:40 PM
My Motion Pro is decent and would recommend them.
Do have a question on the movement going open.
If you put a mark on the END of the throttle tube (horizontally) say 3 to 9 o'clock then rotate to full open where does the marks end up.
Or put another way, how much rotation to go from full closed to full open.
post #9 of 9 Old 08-20-2018, 11:38 AM
when you say heavy are you referring to the initial twist from fully closed. For example your throttle is closed because you have lean angle going on and then corner starts to open up so you are getting the bike slowly straight up and beginning to open the throttle. That initial opening effort is that the heaviness you are referring to? If that is it mine does it too.
2004 Suzuki GSXR 600 (sold)
2015 Kawasaki 636 (current)
DARKNIGHT636 is offline
Fitting the quick action throttle... Jmpr12 Mechanical and Technical 2 05-22-2011 05:03 PM
Quick action trottle kd283 Mechanical and Technical 2 05-13-2011 12:30 PM
