yea, just removing the cables will result in the FI light being illuminated
surprised theres no plate with the TwoBros
Just remove the cables AND the servo motor entirely and plug in a servo buddy.
I got mine for $35 shipped off a member on here. 09ZX6R
Thanks for the clarificationyea, just removing the cables will result in the FI light being illuminated
The plate just allows the servo motor to index itself and tricks the ECU into thinking its working normally.+ There may be a plate but from what the instructions show it just shows as remove, so when i pick it up i'll check the contents and see.. but if there is, how does the plate work?
also if i leave the FI light on for a few days, will this cause issues or limit power etc?
Perfect, the help is much appreciated!The plate just allows the servo motor to index itself and tricks the ECU into thinking its working normally.
No, the FI light can remain on indefinitely with no negative consequences.
I believe the 09+ models are different. Previous models require either a plate or a servo buddy to keep the light off.I pulled my servo cables when I installed the exhaust on my '12 and its fine. I thought you actually had to remove the servo it's self to make the light come on?
