1 - 5 of 5 Posts
Whats Up Guys! So Ive been having some problems with my 09 zx6r , when i take off it seems to sputter / bog alittle, once im rolling it rides fine , but if im on a wheelie and im on high rpms it sputter again. I was told the ECU is from a 13+ and its flashed. Im thinking thats my problem but not 100% sure.
thanks in advanced!
If you have the time and money, put the thing on a dyno, so you can get a baseline of what's going on. Otherwise, you'll just be throwing parts at it until it gets better, or you get frustrated.
Before that dyno run, do a tune up on the bike. Set the valves, put in new plugs and filters. Makes sure all of the running gear is in good shape. Chain, sprockets, clutch, tires....suspension. Do a close inspection of the electrical system, looking for loose connections, corrosion inside quick disconnects, and the quality of the connections to chassis ground. Take things apart, and check.
It may plug in and could perform most functions.... Should be having issues with the secondary injectors, as '13+ don't have them....
Thanks for the feedback, im going to try to clean my tank out as i just got a stunt tank that had sealant inside, maybe its clogging up my fuel pump. If that doesnt do it ill just be taking it back to a shop.
1 - 5 of 5 Posts
