Hello guys, I have maybe one stupid question 馃榿 .. i crashed my 2011 zx6r and the frame cracked. So, now I鈥檓 searching for new frame.. is the frame from zx6r 2006-2008 same as zx6r 2009-2013 ? Thank you for answering..
There are slight differences to the 13+ frames. Specifically, the frame grounds for the wiring harness are on the opposite side. Also, the mounts for the fairings on the 13+ use a bracket attached to the inside of the frame via a hole and expanding rubber nut that does not exist on the 09-12.
Both of these things can be easily worked around.
