Zx6r dies randomly , fuel light flashes.
5.8K views 38 replies 8 participants last post by  zaxzx6r
#1 ·
2006 zx6r , 7k miles
Just bought the bike ran great the day i bought it
All ive done is:
Stator cover and gasket ,
Oil change ,
Had my buddy at gilbane motorsports adjust my clutch to factory specs
Also i placed a jumper wire from the fuel pump ground passed the connector to my negative battery terminal , my fuel pump was not priming because of a previously burned ground that the previous owner tried to fix.
Any ideas on what my issue could be?
Im not good with electrical so i wouldnt know why my ground i made would cause this
Ecu overheating? I have a straight pipe on my bike so its not really very close to my ecu but who knows
A friend of mine suggesting my ground could be overheating my pump causing it to want to shut off. I didnt understand that.
I noticed today that it seems to only do it on hills. Like lets say im doing 35 in 4th going down a hill , clutch in for a second and coast then try to revv match and next thing i know she shuts off.
The other odd thing i noticed is at a stopsign today i was at an incline, she died about 15 feet back and wouldnt start back up on the hill but i rolled it flat and the fuel light stops flashing and shes back to life!
Anyone have any suggestions? All help is much appreciated. Im a car mechanic so i understand engines but im still learning about bikes they are a whole nother animal.
#2 ·
If you are a car mechanic then you would know where to start. Just because the engine revs higher and there are 2 less wheels and you are exposed to the elements. Does not change anything really. Not trying to be an ass or a dick but if you are a mechanic like you say you are, you should be able to figure this out. Or take it to a professional. I would first start by un-mickey mousing your fuel pump ground/wiring and get it back to factory condition in that regard and move forward from there. Check for proper voltage and resistance in that wiring. Start at the obvious first.
#6 ·
just cause I'm a mechanic doesn't mean i don't have weak points. where i work i do a lot of parts changing not diag. how would one restore it back to factory after its been altered>? besides buying a harness.
i wish i had a picture to show you.
#21 ·
#23 ·
apparently this problem is more common than I realized but it seems no one is straight forward on the solution, from any of the threads I found.
the other 2 wires on my fuel pump harness are slightly charred but don't look like they would be "bad". do you think I would need to replace all 3 wires?
#27 ·
She I fixed my one I went through all the wires looking for damage. When I found something all I did was cut the wire slip some heat shrink on and join the wire back together.
I think what caused mine to burn out was the cable kinked. There is a pretty sharp angle in the loom at this point.
#28 ·
See my ground is bare wire all the way to the connector.
I dont think i can clip and splice quite like that. Maybe if theres other damage too but my ground is toast. Im going to replace it with same guage wire , but cant seem to get the wire out of the clip, any tips?
What i have read is that its most common to happen by the gas tank and positive making contact
#29 ·
I had to replace the entire earth wire.
I used a very small electrical flathead screw driver (about 3mm head on it).
Push this into the connector and use it to push down on what is basically a latch to stop the wire from coming out of the connector.
It's not particularly easy and it's quite awkward but easier than replacing the entire connector
#30 ·
Easy enough i got it done , didnt have the connectors i need at the store so i used a wire out of my old broken headlight it had the same end as the one i needed and looked shiny and new! Hopefully i can get it back together tomorrow and seeif it solves my issue
As far as i can tell the ground wire is the only one that burned the other connectors all look good if i shine a light inside them.
#34 ·
well I used a ford Taurus harness to get the connectors I needed , soldered my connections and put in 2 new wires going to the fuel pump plug. she runs like a dream again. woohooo thanks for your help guys! I now understand wiring a little better, so I learned something.
