1 - 20 of 54 Posts
Hey All,
First of all let me say that since I bought the zx6r 2015 half an year ago I was lurking here, but after I encountered an issue I had to join the boat and start a thread which going to help to everyone who is in need of steering damper for the zx6r 2013+ model.
So my story is that I bought a steering damper from Bitubo which I was certainly sure it will come with the mounting brackets, but sadly it didn't so now I'm stuck with a damper with no way to mount it.
So lurking in this forum i found this thread: https://www.zx6r.com/zx6r/39397-2013-636-steering-damper-question.html
It was very informative but both those parts:
11056-2308 - Triple bracket
11056-2315 - In front of tank bracket
Cost a total of 150$ (that is without my country taxes which will make it 250$).
I started looking for a bracket that will fit or make a bracket, so I got some Chinese "Matris" zx6r mounting bracket but the diameter of the clamp is big (25mm while the Bitubo is 22.8mm) and I have to use something to fill the gap between the damper and the clamp (big room for errors).
Instead I kept looking and found this part:
11054-1903 - Triple bracket of a zx10r 2010, cost me 10$ on eBay, now all I had to do to fit the part to the triple, this required modification and basically just make on of the holes bigger (used a drill and just drilled a bit and checked a couple of times until the hole was perfect size), when you install it you'll see that there is a part touching the clip-on secure bolt, so i just used a small spacer and now the part is sitting great with good clearance to the gas tank.
Now I have to find a gas tank bracket, I ordered a zx6r 2009 bracket because i understood that it can be used on the 2013+ model (Part: 11055-1147 cost around 18$) but it's on a back order, So I'm thinking of getting the original one that fits 11056-2315 which is like 37$ (Double the money) and there is the zx10r mount (Part 11054-0023 / 11054-0023-18R) but not sure if it will fit on the zx6r.
Meanwhile hopefully the part will arrive soon so I can update with pictures.
Thanks for reading and hope it helps anyone.
*The steering stem bolt and weird gold bracket in the pictures is from the Chinese bracket.
Discussion Starter #2
** Update
So partzilla just told me that it's on back order and it nation wide or something like that which means there is no ETA on that.
If someone is selling this part: 11055-1147 please let me know, right now project is delayed until i can get my hand on this bracket.
I bought a Chinese type damper just for the fitting kit for the reasons you describe. My plan is to replace the damper tube with a well known one once i get to give it a try.
Not sure if this is any help to you.
Bike looks nice!
Mind checking the damper diameter for me? It'll be very helpful.
Thanks
Discussion Starter #7 (Edited)
what does the ohlins mounting kit do that the above doesnt?
Ohlins mounting kit doesn't fit the Bitubo damper, i tried it.
The Matris / Hyperpro can fit but the diameter has differences.
On another note to help everyone who wants a bit of overview options for steering damper:
OEM ZX6R steering damper kit (the Kawasaki version Ohlins SD021) is a BS damper and needs to be revalved (even if you buy the kit from factory).
The Ohlins SD042 is the steering damper you want if you into Ohlins, only thing is that this damper cost a fortune.
Both kits comes with mounting parts (SD021 comes only if you buy it from Kawasaki dealer since the mounting parts are not made by Ohlins but made from kawaski, parts are: 11056-2315 and 11056-2308)
Now for alternative you have:
GPR V4 - great damper but heard it has to be maintained quite a lot due to leaking from now and then, comes with mounting kit.
TOBY - didn't really get a review and feeling of it but heard it's nice, comes with mounting kit.
Hyperpro - heard good things on them, comes with mounting kit.
Bitubo - I got this one, heard good things on them tried it and got one, but it doesn't come with mounting kit so you have to buy / fabricate kit (reason i made this thread)
Gubellini - well made damper but no personal experience. (Don't know if it comes with kit or not)
There are more out there... just make sure you get a mounting bracket with it else you'll have to get those 2 overpriced parts (11056-2315 and 11056-2308)
Ahhh, well - that scuppers my plans! I was planning on getting a hyperpro as the one on my zx10r worked perfectly well and wasnt insanely expensive.
I'll report back if this chinese one lasts more than 1lap :laughing
Director of Moderation
Buy once, cry once!
Yep! And if you're on a budget just buy a used one. There are lots for sale in great condition. I bought one for $225 in perfect condition that I used for like 4 years on a different bike. The one on my R3 I think I got for $200, but then I had to buy mounting brackets from Graves so that brought up the total to about $300. Still way less than $500-600.
The thing I like about Ohlins (besides that they're the best at what they do), is that there's a lot of literature out there for their products and you can learn how to service them pretty easily. And if you don't want to, there's always a shop that has the tools and knowledge to work on Ohlins. Bitubo though...Bitubo who?? :O
First bought a GPR, it needed to be reworked as it was leaking and was too stiff. It mounts very close to the key so depending on the key, the key may need to be trimmed. Mine didn't but was very close. Sold it at a loss (buyer was aware of issues) and bought an Ohlins from someone on this forum. It was expensive but the quality was first class - as I expected. Mostly titanium parts and everything was very light. I just ride street and bought it to prevent the unexpected tank slapper that could put me down. Some things I'll cut corners on but tires and brakes and important suspension parts are thinks that really need to work well. If it doesn't run that is a problem but not like brakes or tires not working. Know a lot of folks are on a tight budget, will be interesting to see how the Bitubo works out.
Except when that Chinese crap either starts leaking in a few months or just needs the normal rebuild you’re screwed and have to buy another. While with the ohlins a simple rebuild and it’s like brand new again. Why waste your money on literal trash? Let alone for something as vital as a supersport motorcycle, at least for me I don’t want to cut corners on a small unprotected piece of metal flying me at 150 mph lol. But then again, someone has to keep the CA motorcyclist down Instagram page going... lol
Bitubo is Italian btw...
There are a lot of chinese replicas of various types of steering dampers on ebay for really cheap. I would certainly stay away from those. Mainly cuz I had one lol My CBR500 came with a chinese replica of a Scott steering damper. My ZX6R had a real authentic Scott damper. They looked almost the same, but the difference in how they worked was night and day. The real one actually did its job well and everything worked on it. The chinese one was way softer on the damping, and the adjustment knob did jack shit. You could turn that thing in either direction and there was barely any difference in feel lol
Would the chinese damper still be better than no damper? Serious question lol
1 - 20 of 54 Posts
