1 - 5 of 5 Posts
Hi guys,
Just bought a ZX600-G2 a 2000y. model.
The speedometer dial is in KMH but the needle works in MPH and its very disturbing, as I drive in Europe, I need KMH.
Just like this, I read the manual but there is no guide for MODE and RESET to switch it to KMH,
My guess is to change the speed sensor ? As I already tried another Speedometer...
thanks.
Looks like it's reading too fast, 160 mph would be 260 kph. Are you going that fast ?
I dont think the issue is that it is showing mph but that your speed sensor is shot.
Reactions: Hakashi
Might be an aftermarket 'Speedo healer' in line as well.... That could be failing, or making a correction for mph instead of kph.
Do you know if the bike has OEM final gearing? I'd guess 16 front, 43 rear?
Apologies, I forgot to mention thats a pic from the internet :)
Well the gears are all stock from my understanding.
Already changed the speedometer and the sensor, still the same, found a small adapter in between the sensor and the speedo last night, seems like a converter (Speedo healer???), removed it but it was raining heavily, so had no time to test it out. Will try today ;)
here is the picture of the thing, no number no ID, nothing, just a black sealed box.
https://i.imgur.com/y1rnK7Y.jpg
UPDATE: Just took it out, great weather, and the speedo is showing KMH! Finally ;) that was the problem.
https://www.photobox.co.uk/my/photo/full?photo_id=502033881264
Glad it was a simple fix and you got it figured out.
Reactions: Hakashi and RJ2112
1 - 5 of 5 Posts
