The rebound adjuster was probably set incorrectly when the fork was reassembled. They have to be preset before reassembly or you can have issues like this.
Set the distance between the upper end [A] of the spring
preload adjuster and rebound damping adjuster [C].
1.5 mm (0.059 in.) [D]
That's the section in the manual that covers it. It's in the fork oil change section.
That is the most likely cause.
