This occurred on my '09 ZX6-R9F recently:
So about a day ago as I did my pre-work bike check I noticed that something seemed unusual about the way my bike was idling. With no FI light on, no oil or fuel or coolant on the ground, and no strange odors or smoke I decided to head down the street and back to see if anything would crop up that I could address. Before I could even get down the street (1/2 mile to a nearby high school parking lot) the bike was bogging down if I let the throttle go so I stopped immediately and shut it down.
One quick look confirmed that there was a low oil level in the bike which is crazy because I checked it the night before and it was nearly full. no oil on the tires, none on the ground. A quick call to a family member had me with several new quarts of oil. The bike never reached over 180ish, so temp was not a problem ( it was around 92F outside at the time) After making sure it was filled back to a proper level I promptly put it right back in the garage and began to tear it down.
Low and Behold! The small plastic oil/water catch from the air system hose had somehow managed to blow a hole in itself to the point it looked like the chest of one of those victims in the Alien movies (from the inside out mind you). Blasting the majority of oil all over my lower fairings and covering it with dirt so quickly that it had not run down onto the ground at all.
With the black charred edges I just assumed that it somehow had caught too much heat from being near my headers (a crack maybe?) but the way it was blown out from the inside indicates internal pressure. (which could be normal, though my NOOB self has no idea yet)
The part about the pressure does have me a bit worried because as someone fairly new to mechanical troubleshooting with bikes, that could mean a number of things if it is not standard. (wouldn't know yet, as it is my first bike. Though I do know that a small amount of oil/water runoff is normal and can be emptied out.)
Once I had it back in the garage the bike itself, idling and revving did not spit any oil at all from the line, until I put it in gear.
Obviously, I cannot ride until my new little plastic container comes in with oil spraying all over a hot exhaust and engine block... and definitely not worth wasting time with a plastic piece if the primary problem is elsewhere and I need to start breaking down components.
So I am here at the home of the forum gods to beg forgiveness for my ignorance.
I am currently looking through my service manual to gain some insight as to what exactly is going on and what I would be looking at doing IF I needed to start planning for more extensive repair.
I was still over 1k miles from my next oil change, oil was properly leveled, new k&n oil filter. Coolant with less than 2k miles and plenty in the system. Mobil1 4t racing 10w40. I don't ride hard either, I have been using it as a daily back and forth to work ATM
Any suggestions or clues as to how something like this could have happened? I am currently thinking a possible cracked exhaust or a case of the actual tube being located too close to it at the very least. However I do not see any visible cracking at this time.
Any help is GREATLY appreciated.
P.S. if you are wondering what catch I am referring to, see the Kawasaki service manual for a 2009 zx6-R9F PDF page 222, Figure 2, A
