1 - 5 of 5 Posts
Recently got into an accident and don't want to shell out the $800 for an OEM exhaust that the shop is quoting me for.
Looking for anything that will fit a '13 ZX6R. Prefer to spend under $400, maybe spend more depending on the slip on. No dings or scratches please. Definitely interested in a Graves slip on the most though.
Thanks.
A change in volume, without a huge outlay in cost may be as simple as replacing the mid pipe. The OEM resonant box is quite heavy, and locates quite a lot of heat near the rear shock absorber.
Ixil makes a bolt on straight through pipe that can replace that entire assembly, and mates up correctly with the OEM muffler. These sorts of pipes can be had for less than $100, to multiple hundreds depending on who you buy them from and which mfg is selling it. Ixil is the least expensive option as far as I am aware.
1 - 5 of 5 Posts
