Which levers are right for me? A quick guide.
25K views 75 replies 33 participants last post by  Strider
#1 · (Edited)
I often get asked which levers are best for <X> type of riding so I thought I should finally put something down in one spot for it.
This will not cover brands as I will leave that to your personal preference. Rather I will discuss the different styles and the pro's and con's of each.
OEM Style
The ones that came on your bike from the factory.
PRO's
  • Inexpensive: Your bike already has them and generally they are inexpensive to replace.
  • OEM Fit/Finish: This can be good or bad depending on your brand.
CON's
  • Ergonomics: Most OEM levers are not terribly welll designed with an awkward slope that our hands do not naturally fit on.
  • Cheap: Due to manufacturing basics, they are usually made from cheap metal which breaks easily. Sometimes called "pot" or "white" metal.
  • Lack of adjustability: Most OEM levers offer little to no adjustment.
  • Lack of style: Let's face it. They just don't do much for the aesthetics of the bike.
Recommendation
If you already have them and don't particularly mind them. Keep them. If you run a dedicated track bike I would suggest replacing OEM with a quality aftermarket unit. See below.
Standard length / Long levers
Usually made to accommodate the full hand/4 fingers
PRO'S
  • Finer control: The extra length means that you can have finer control over what that lever does.
  • More adjustability: Typically will have a better range of adjustment than OEM.
  • More Leverage: As the job of a lever is...a lever. The further away from the fulcrum you get the more pressure you are able to apply. Longer levers means it can be easier to to move a difficult control (cable clutch).
  • Stylish: On a 1-4 scale I place these at a 4.
  • Customization: Most aftermarket levers will allow you to dictate the color choices of the lever and/or adjuster.
  • Ergonomics: These tend to fit your hand well, are wide and comfortable for extended use. They provide excellent feel/feedback of what the motorcycle is doing.
CON'S
  • Expensive: As a general rule most aftermarket levers are more expensive than the OEM counterparts. A single lever can range from $25-$125 depending on brand/options
  • More Leverage: This is a con as well as a pro. In the case of a brake control, if you panic and grab a handful of brake, it will apply significantly more force with a long lever than it will with a shorty.
  • Length: The extended length means that the lever is prone to hitting the ground if the bike goes down. This can result in bending/breaking the lever.
Recommendation
I usually recommend standard length levers for bikes which see primarily street duty. The extra leverage comes in handy when working a clutch in traffic, the ability to customize the colors means you can make your street bike your own, and the con of possible breakage if the bike falls over is minimal.
Shorties / Short levers
Usually made to accommodate 2 fingers on the lever.
PRO'S
  • Stylish: On a 1-4 scale I place these at a 2. They look "cool".
  • Length: Because of the shorter lever, it is less likely to contact the ground in the case of a crash. This can be beneficial to track riders/racers.
  • Ergonomics: More comfortable than OEM but not as comfortable as standard length. They provide excellent feel/feedback of what the motorcycle is doing.
CON'S
  • Expensive: As a general rule most aftermarket levers are more expensive than the OEM counterparts. A single lever can range from $25-$125 depending on brand/options.
  • Less Leverage: Due to its very nature, the shorty lever cannot apply as much force as its longer counterpart.
Recommendation
I recommend these for bikes which see a lot of track use, for street riders who want a big "cool" factor on their bikes, or where the lack of leverage will not pose a problem.
Folding Standard / Long
Usually made to accommodate the full hand/4 fingers. These levers have a folding point which allows the lever to fold upwards in the event of a crash.
PRO'S
  • Stylish: On a 1-4 scale I place these at a 3.
  • Folding: This can be a huge benefit to bikes which see sustained track use as it is intended to keep the lever functional after a crash.
CON'S
  • Expensive: As a general rule most aftermarket levers are more expensive than the OEM counterparts. A single lever can range from $25-$125 depending on brand/options. Folding levers tend to be on the higher end of the range.
  • Quality is critical: If tolerances are not tight, the lever can quickly feel "sloppy" and you could experience a loss in feedback/feel.
Recommendation
This would be my #1 pick for track/race bikes. A rider gains the benefit of the finer control that comes with the longer lever without the risk of breakage due to the folding component. Also great for street riders who want more bling than a conventional standard lever without sacrificing function.
Folding Shorties / Short levers
Usually made to accommodate 2 fingers on the lever. These levers have a folding point which allows the lever to fold upwards in the event of a crash.
PRO'S
CON'S
Recommendation
For people who want the ultimate in "bling", these are it. All the cool factor of a short lever with the folding component thrown in for good measure. I would recommend these for track riders who do not necessarily need the finer control offered by a longer lever or for street riders who want the best of the best.
A quick note
Some companies will sell mixed sets of levers allowing you to choose short or standard lengths for each lever: i.e. you could buy a standard clutch lever and a shorty brake lever allowing you to receive the benefits of both where they are needed most and further enhancing your ability to customize your ride.
#5 ·
I assume you are referring to the notch near the bottom left of this lever, just after the ball end? That is a relief cut which basically provides an intentionally weaker section into the lever so that if you crash and the lever catches, the idea is that it will break away at that spot which will still leave you a usable lever after the crash.
is there any way you can do one on rear sets?
Unless I am missing something there don't seem to be as many different types of rearsets, just different brands. Some just an adjustment plate, some don't but that is about it.
What I can tell you is to stick with a quality brand. I personally run Woodcraft because 1) trackside support is awesome 2) I like their pegs better than Vortex and 3) I race with the owner =)
#6 ·
Lol.....ok thanks for helping me out. I was asking about them because I hear about people switching them out. I was thinking....what for? Do they break over time? Are they uncomfortable do to your foot not fitting in there properly? I do not plan on switching mines out. Just wanted to know why people use aftermarket brands....thought it was a performance thing.
#10 ·
For track use, having fixed rearsets means you have a more stable perch. Also, most aftermarket rearsets move the riders position back and up a bit into a more aggressive stance which provides more ground clearance than OEM. Sorry, I misunderstood your question =-).
Good Info, thanks. I just bought some MadScientistMoto levers. They look pretty straightforward to install, but how about a video overview? I was planning on lubing my clutch line at the same time.
First, thank you for supporting my little business. I truly appreciate it!
Second, that is a brilliant idea. I actually have to install some levers on the wifes bike so I think I will make a little video from it.
#8 ·
#14 ·
To be honest I have always thought of these as kind of a gimmick. Once you have the length you want you will leave it there and generally speaking you either want your whole hand (standard) or partial hand (shorty) on the lever.
I suppose that if you have oddly sized hands you might find some use for it but really this just comes down to personal preference. If you like them, buy them =) At the end of the day they do the same job as every other lever out there.
#17 ·
Correct. Levers are made of 3 main components: The adapter (the part that is specific to each motorcycle, the adjuster, and the lever itself. The adjusters and levers are universal.
If you are referring to my site, then yes, right now the ZX6R clutch adapters are out of stock. You fine people here have ordered more than I was expecting and it caught me by surprise. I have my stock order from the machinist already in the works so I should have them back in stock in about 10 days.
#25 ·
Still in the R&D phase - working with prototypes now and determining some of the aesthetics. I wish that I could give you a hard and fast date but I simply can't at this time as there are too many variables. I would *hope* that it will be within the next 2-3 months but that could vary by a lot.
Well I can say the 3D doesn't necessarily do anything for grip as far as I can tell, maybe a little, but I have to say, I own some, and the 3D effect actually looks pretty good. It's obvious that it is a purposeful addition in production, not a byproduct of some production failure.
Anyways, could you elaborate somewhat on how you hope to accomplish a "grippier" surface on the levers in your premium line? Are those tolerances in english or metric? And are those for both the feature's positioning and diameters?
It has been my experience that all levers can offer less grip than I would like. My fingers slide around too easily on them, especially so in rain riding. The trick is finding the right level of texture to use to give what I am looking for. They do need to be able to move freely but just that little bit extra of feel when I want them to be firmly planted. I actually think we are pretty close to nailing that down.
I am certain that those 3d levers were intended to look that way, I simply stated that to me it looks as if it is unfinished. If you have ever seen machining done (and I am guessing you have by the fact that you are asking so many pointed questions. Makes me wonder why you want to know) it looks like a rough pass before you make a finish cut and it was left that way.
Those tolerances are in English, so thousandths of an inch. Ten thousandths is a pretty standard tolerance for non-critical part when providing a slip fit but again, none of these that I have QC inspected have ever gotten anywhere near that sloppy.
Hello Painfullyslo,
Green adjusters came in, soon to be on bike. Thanks for the time and trouble. I do appreciate the extra time you took to look the red adjusters. I was a little bummed but when the Green ones cam in , totally changed my mind, love them. With the customers service you provide I have no doubt you and MSM will be around for a while a Long While!! I will be looking for a pair of boots in the next month or so.
Glad that you are liking them bud. I am still bummed that I couldn't find you some really bright red adjusters. If I ever get around to making a run of them I will be sure to send you a pair.
As for the boots, awesome! let me know and I will do what I can do to help.
#24 ·
Hello Painfullyslo,
#30 ·
Nice guide dude! You should put links to your products in as examples tho :bigthumb:
Reactions: THUG and kawijay
#33 ·
Got my levers that I ordered. Thank you! Once my clutch cable comes in the mail and I replace my clutch plates I'll try it out.
Thanks for fast shipping. I'll order the new brake lever soon.
#35 ·
It all depends on what type of riding you are doing. For everyday ASV shortie levers are perfect for both braking and clutch. Breaking because of using 1 finger to stop, that gives you better controlled and smoother stopping. Using 2 fingers for an emergency braking, in like using a fist full to grip ur front brake which will cause you to flip over your front wheel.
As for the clutch shorty lever gives you a better grip on your handle bars for better control. Good luck and ride safe.
#36 ·
:coocoo
Not even going to touch this so I will just use your own quote. Good luck and ride safe...
#38 ·
I can't stand stock levers usually, but it really depends on the bike. I have midget hands apparently, cuz I can never get comfortable with them. Hence I had MSM levers on both bikes :D
But the deem150's explanation is hilariously wrong lol...I do use short levers on my R3, but that's only because of their position relative to the end of the clip-ons. Regular sized levers would stick out too much which would mean instant snap during a crash. The short levers on the R3 feel like regular levers on the ZX6R or most other bikes I've ridden.
#41 ·
Yes u are rite I do. It need to share any of my knowledge about levers that u can not afford, lol, I wanna see u roll an endo for 300 feet one handed, go chose ur levers, good luck grammar guy, ?????? then we can talk. Sorry for the miss spelling, Russian bread “xyyasos” go and advertise ur 12$ levers and use them since ur pockets are shallow ???????
#45 ·
Gandon no pidar for shure ?☝
Stock buddy
Stock. Can you read that. Did I miss spell? Let me know I’ll help you�� I have 3 brake levers for sale MINT!!!
Braking rotors from: BCS PERFORMANCE he is here local in the US, really cheap,
WRS.sm is the online store located in Italy where I bought my Brembo 19RCS complete with the brake fluid bottle for $290 shipped, it arrived in 6 days.
I'm so confused what is going on here lol...what are you on about?? Levers, random words, some gandon no pidar (whatever the hell that means), then all of a sudden talking about some rotors and a Brembo MCS :cuckoo: This conversation took like 4 turns within a few posts.
I also like to wash my bike because the swing arm angle is just right then and only use kerosene in the tank because otherwise the tires don't last enough and I don't use the turn signals so I can get more power through the turns :laugh
#48 ·
Deem 150 is all butt hurt because I called him on his earlier stupidity that he posted......
Now he just doubled down on the stupid factor. he still has zero clue what he is taking about or who is talking to or even what he said was so fucking ignorant!
